Hey guys
I've put a new pod filter in my skyline due to the piping of the FMIC
anyway it's making shitloads of boost sound even at 2000rpm
is there a way I can control that like buy a boost controller or something???
I really have no idea about forced induction stuff
so if any1 has a pic of where they installed their boost controller that'll be much appreciated
Thanks
I've actually got the airbox, the brand is the netami gold pod filter
there is a hole where the old SMIC piping was,
of which I connected a tube for air intake under the front bar
it makes less noise with the air box but still quite annoyiny when all I want is to drive it normally
the standard airbox can be modified but I'd have to cut a large chunk out of the air intake
which will render it to be not very efficient
Edited by POLICE
When you gota pod filter on, it will make that sucking noise. Its what a pod does.
No point putting a boost controller in to lower the boost on your stock turbo. (BTW Your turbo is stock right?)
I like have the sucking noise with my car, sounds great!
What material is it made from? paper? cotton? steel?
If you want to keep the pod - get one that is paper or cotton - that will quiten it down.
else
fit the stock air box up with a paper or highflow panel filter.
i know what you could be going through, i just took the pod filter of my v8 ute and put the the big airbox with over the radiator surround intake (mouth) because the sound of the induction noise on the pod (paper filter) was very loud, even idleing...
but the HKS pod pn (foam pod filter) my r33, the induction noise gets louder when you are comming onto boost, i do like the induction noise it gives, a deep howling noise...
The induction sound is air sucked through the pod AND the compressor turbine spinning and compressing that air, which was previously muffled with the stock airbox + filter. It's normal (and sounds sahweet) as you come on boost from around 2000RPM+.
haha @ GTST.
There is no way of getting rid of the induction noise with the pod, even if you box it. You'd need some thick heat insulation in there to make quieten it down, but even then I'd highly doubt it'd get rid of the noise like a stock air box.
Pod induction noise, you either love it or hate it. Or just learn to live with it.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
