I'm soon to head off to Europe for an extended working holiday, i'm getting an Ancestry Visa, and i was thinking about a private import to bring back, as i will be there for more than a year,
The car will be for my father, and he's looking at a few things mainly the CL500 merc, newer model
I've done a search and not much returned info about importing from Europe, is this any different than say Japan?
I'll more than likely garage the car most of the time, but leave it rego'd and i'll have an international drivers license, so i might just have to take it for a spin occasionally, but will me being an aus citizen, will it classify as a personal import?
Also what other options do you think would be a good candidate?
Dad's business is in real estate http://www.reod.com.au and he already has a 2000model Range rover, and was thinking this would be the next thing to get, rangie for country properties and this for the city ones
Another option would be the new Range Rover Sport supercharged :down: alll because they are a lot lot cheaper overseas than here
Anyway, any help would be appreciated in regards to the inporting side of things and if i qualify
and also a selection of cars that would be nice or even profitable to sell again
And i'm aware that getting a new expensive merc as a grey import would be hard to sell here, cause everyone wants proven history etc of the vehicle
Thanks in advance
https://www.sau.com.au/forums/topic/221598-importing-from-europeuk/
it is no different from importing from any other country. doesn't matter if you are importing from england, or brunei or japan. any questions about the rules of personal import should be directed to DOTARS as they are the ones who will process your application not us. it won't help if we say "sure international licence is fine" and then they turn your application down. saying to them, "well beer baron told me it should be ok" won't help. trust me! talk to DOTARS, they are not the enemy.
If you are going to bother bringing something back then make it something that was never sold here. Eg anything with Cosworth in the name, a Lancia Delta Integrale, an early BMW M3 (LHD so not sure if you can rego them outside WA)
Don't bother with common or garden variety stuff.
Atom Ariel for the win!
I can't see this getting rego approval here anytime soon (been watching their website for a few years now).
You would either be unique in Oz or turn a decent profit to have the only road registerable one (that I know of anyway) in the country.
  • 3 weeks later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
