Ok so my DVD player recently decided that it wouldnt read any DVD's anymore, Im pretty sure its because it is about 3 or 4 years old now and the laser has crapped itself.
I hear that DVD players, CD players etc have a life of about 4 to 5 years (depending on how often you use them) because the laser eventually degrades to the point where it wont read anymore.
Firstly - Is this true?
Secondly - If I use my PS3 as my DVD player aswell as for playing games will it decrease the laser life significantly (I do watch a fair amount of DVD's) or am I being paranoid?
https://www.sau.com.au/forums/topic/221612-playstation-3-as-a-dvd-player/
pfft i watched countless movies on my xbox 1 and got it on launch day it never had a single hiccup.
I would really reccommend a ps3 as a dvd/blu ray player they are really good.
However i dont know what its life span is, the ps2 sucked bad as a dvd player cause of a shitty laser. I would bet the ps3 would have learnt its mistake and it looks like they has the best entertainment player on the market at the moment.
It is true they dont last forever, But fortunatly the Laser diodes can be easily replaced with a new one. No need to stress about playing DVD's on your PS3.
Im certainly not an electronics expert so this may seem like a dumb question, but... How would someone get the diodes replaced if they needed to?
Theres a guy in conder who im 95% sure could fix it... PM me for the details if you want them.
The laser in the ps3 wouldnt be reading much differently on a dvd than it would a blu ray (for games etc)... same goes for xbox 360 games and dvd's... if you cant play a dvd on a dvd player (which is what both the 360 and ps3 have) as much as you want, then its pointless... so i dont know how much truth is in "the more you play dvd's, the more the laser dies" story... i would almost guarantee its just the general life of the laser in your dvd player, or just needs a thorough clean...
Edited by SKYLVIA
ps3 and xbox are dvd players?? r u insane?
So if PS3 and Xbox 360 can both play DVD's perfectly fine, what would you call them? 360 games are on DVD's, and the 360 reads them, and plays them, hence "DVD player"
I know what your saying, that its a Blu-Ray player with capabilities of playing DVD's, but some people really cant be arsed to write "Blu-Ray player with capabilities of playing DVD's" or "A device that can read and play DVD movies/PS2 games (Also stored on DVD's, but only capable on 60gb models)".
Edited by SKYLVIA
Well I dont know, but I must say the upscaler on the ps3 works a charm and the picture was so much clearer than on my mates conventional DVD player.
R u running ur PS3 through HDMI?
Edited by Mayuri Krab
Ps3 native scale is 600p, it upscales to 1080p if the software enables that format
I have my PS3 running directly into my HD LCD screen via HDMI and the 1080P picture absolutely awesome, Ive never seen such a clear image.
I have 2 questions for anyone who considers themselves a bit of a PS3 expert:
1. When I watch DVD's on my PS3, every half hour or so the sound drops out completely for about 1 or 2 seconds, why would this happen? (I have checked all the sound settings and they're all correct and all cables are properly plugged in).
It doesnt do it during game play though.
2. What is an "upscaler" and why would you use it?
1. Difficult to answer without more info what sound system do you have, if its a 5.1 system it might be from lights getting turned on and off which can interfere with the frequency but it could be many other things. Just ceck your connection and make sure you have the sound settings set right for your system.
2. Upscaler is automatic, ps3 is 600p. If a game supports a higher scan then the ps3 will up scale to its optimum.
example if the game says on the back 720p/1080i/1080p it can run at 1080p max but that will be upscaled from 600p.
Thanks for that Pat,
Its not a light switch problem.
Im running the sound from the LCD to my stereo amp witch is 2 channel only, its an older HI-FI set up with all individual units (amp, graphic equaliser, cd player etc are all separate) and the setting on the playstation is for 2 channel linear 48khz which was the auto set when I set up the sound options...
I'll have another look at all the cables and see if they arent kinked or not connected properly but Im pretty sure that they're all fine.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
