Should be able to do it ur self.
Not that difficult, normally they will plug into exising wiring. Depending on qaulity of kit.
Few cable ties etc, should make all the wires all neat.
If you really dont want to do it ur self... places like EVO R in bently etc, should be able to hook it up for you pretty easy. Less then an hrs job i would think.
https://www.sau.com.au/forums/topic/221630-hids/#findComment-3907674
There EZ mate i just did mine today. All i had to do was solder the earth wire to the existing earth wire from the connector on the housing. I wanted to use the existing earth wire so that's why soldered them together.
The rest was just plug em in sweet as.
https://www.sau.com.au/forums/topic/221630-hids/#findComment-3910718
i have a question
lets say you put them in your highbeams. does taht mean you have to take the high beam globes out to have the strobes in there or can you still have both
You can put it in the high beam side but you can only fit one globe in the housing at a time.
https://www.sau.com.au/forums/topic/221630-hids/#findComment-3919124
Also i would recommend changing your parkers at the same time to a LED or better because they wont look so flash next to the HID as i found out. ASPEC in the city open 7 days sell them for about $25 or $30 cant remember. MotoQuipe at carousel should have them also.
https://www.sau.com.au/forums/topic/221630-hids/#findComment-3927316
    • My TIG likes to remind me I need more practise on the TIG. Especially Aluminium. My mild steel TIG isn't terrible (I'm not writing home about it either, but it at least doesn't just look like gooey metal)
    • No longer need the BOC account. It's all swap and go now from Bunnings/ToolShops. A fair bunch of the time I'm running my 180 on lower settings, and I'll run it on a 15amp to 10amp converter cable. When I need to ramp it up, I presently have 1x15A GPO and I move over to that socket with everything.
    • Welcome, the rb in S chassis is favourite of mine. Lots of info here and a few ways to do the swap back in the day. Post up some pics or start a build thread here  https://www.sau.com.au/forums/forum/190-members-cars-project-overhauls-restorations/
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
