thrust bearing isnt that expensive $60-$100, i cant remember just plucking numbers. I'd say labour is the same as doing your clutch so 250-350 cause your dropping the box out. so its a waste of money i say if your just replacing the bearing unless you got heaps of money to waste...ha. people usually do the bearing and spigot bush when they upgrade their clutch
I went for a good 2+yrs before I replaced it only cause my clutch died.
If you press the clutch and it goes quiet, its the spigot bearing not the thrust
Its about $8 for another one and you need a slide hammer to remove it
If you buy a clutch kit such as an Exedy clutch kit, they generally tend to come with brand new NSK thrust bearings so no point buying one separately to replace, just do it all at once when you do a clutch install
BRUNSKIGTST - its no big deal, change it when you change the clutch
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
