Im sure most of you have heard about ''the peoples chip'' gravy flavour.
when they where released yesterday, it was though that only 495 pkts where ever going to be released.
so as with everything else valuable and rare, several packs have made there way onto ebay, selling for as much as $510!! :wave:
i just want to make sure that no one from SAU is bidding, beacause theyre actually making another 60,000
packs, and im sure they will be a hell of alot cheaper than the going rate on ebay...
why would people want to pay that money for chips? id rather put $500 bucks of ultimate in my tank
would bring more enjoyment :/
bloody scalpers.
https://www.sau.com.au/forums/topic/221700-gravy-chips/
mate most defectable things are visable, you have an rb30det in you car cubes, thats just as defectable as a top mount!
no body ownes me andrew.
Ahh but it doesn't have to be that way.
Here's the RB30DET; most its made is 285rwkw on 17psi; just about to slot a pair of cams in and stick a boost controller on it for 20-22psi.
Looks dead stock. Hell even the exhaust is rather sedate.
https://www.sau.com.au/forums/topic/221700-gravy-chips/#findComment-3909420
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
