Turbo smart bov type2 $90ono
R33 crank angle sensor $70ono
R33 throttle position sensor $50ono
R32 charcoal canister (big one) $50ono
HKS electronic boost controller $350ono
R32 injectors X4 $50
R33 type m (series 1) spoiler $70ono
R33 HICAS rack $60ono
R32 turbo pipe $20
pm me happy to post
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/
price drops
Turbo smart bov type2 $70ono
R33 crank angle sensor $60ono
R33 throttle position sensor $40ono
R32 charcoal canister (big one) $40ono
HKS electronic boost controller $300ono
R32 injectors X4 $40
R33 type m (series 1) spoiler $50ono
R33 HICAS rack $50ono
R32 turbo pipe $20
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3927175
R33 crank angle sensor $60ono SOLD
R32 charcoal canister (big one<>epa friendly) $40ono
R33 Rear HICAS rack $50ono
R32 turbo pipe $20
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3936872
price drops.... and if its not cheap enough make a offer
Turbo smart bov type2 $50ono
R32 charcoal canister (big one<>epa friendly) $35ono
HKS electronic boost controller $250ono
R33 type m (series 1) spoiler $40ono
R33 Rear HICAS rack $40ono
R32 turbo pipe $20
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3941855
price drop to clear this stuff
Turbo smart bov type2 $40ono
R33 throttle position sensor $30ono
R32 charcoal canister (big one<>epa friendly) $30ono
R33 Rear HICAS rack $30ono
R32 turbo elbow pipe $20
Edited by SKYYLINE
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-3977418
this stuff still for sale
https://www.sau.com.au/forums/topic/221702-r33-some-r32/#findComment-4006839
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
