haha i realsied the whole pm thing jsut after i posted, and yeah in the end the s1 would likly be cheaper then a rebuilt on either mine or yours, yeah fixing clutch is needed, lol, and thats a lot of stuff working on lists atm, good stuff to
cheers
alex
Plus you learnt u want a new clutch now (or at least adjustment on yours) hehe
If a S1 turbo works on your car, datto's sounds like the best option. I was also thinking Alex, if you were lookin at mine for a rebuild - might as well rebuild your own hehe
YGPM = you got private message!
dropped off the turbo i purchased of datto today, thanks for that mate, john said it looks fine, and he will be installing it during the week, hopefully all up and going before the weekend, i have also discovered that the microtech lt12 i have dosnt use a o2 sensor, just a random fact for the day.
just figured ild keep you posted
alex
alex
Interesting about the LT12 Alex. Do you know if that means that it would be running in Open Loop permanently since there is no O2 sensor to get readings from?
It sounds like John has a long week/weekend ahead of him. He was saying today that he has to work over the coming weekend.
sfrizza
you at trojan today??? which car is yours??? i have no idea i was puzzled that the micro has no o2 sensor, do you run a LT of some kind 2???
Alex,
Was on the phone to John taking up too much of his time yesterday :-P My car will be going in next Monday whilst I'm overseas for some tasteful mods (thanks Sl33py :-P).
As for the LT12, no, i'm running a PowerFC. I was just quite surprised and as you say, puzzled, that it doesn't run an O2 sensor. I would think it would mean that the tuner is then required to do a true 'full tune' instead of relying on closed loop mode for cruising. I've had no experience with Microtech's so perhaps others with LT10s etc could inform us if its just the LT12 without an O2 sensor?
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
