If you take the car to the circuit, I think it would be wise to upgrade the 5th as well. I use my OS 5th gear a fair bit on the track. It's not that bad on the highway.
Don't waste a well made gear.
When I get home I'll try out the 3600rpm deal and see how she feels.
  • Replies 59
Brockaz is selling his box with the OS set, he should know... assuming 32 & 33 GTR boxes are the same.
Actually I'm wondering the same thing (as I haven't had a chance to research, frantically getting the car ready for Dutton).
My OS Set has teeth missing on 2nd gear, and the input shaft (2nd gear). Every other gear is perfect.
2nd gear = ~$800?
Input shaft = $600 off greenline
Considering this box already has all of the OS parts in it, it's obviously got all the series 3 gear in it as well.
This being said, will I still need the additional $1300 worth of Nissan parts to rebuild my box? I'll be throwing a new set of synchro's in there while it's out as well.
If it's simply $1400 for parts + $700 for labour, I'll be getting it rebuild asap.
Edited by Brockaz
I haven't got the translation of the parts list yet Brockaz. My assumption is that the list is a standard rebuild kit and only changes depending on what year/evolution of the g'box you have. So if some of your gear is OK some of the extra expense wont be needed.
Ok, so I managed to get into my friendly neighbourhood Nissan dealer for some numbers...
Pt# Description Quantity
32604 - 30P60 Ring Baulk 1
32604 - 30P61 Ring Baulk 1
32604 - 40P61 Ring Baulk 1
32606 - 30P10 Sleeve-CPRG, 5th 1
32611 - AA510 Sleeve-CPRG, 5th 1
32605 - 310P11 Hub Synchro 1
32811 - 05U10 Fork shift 1
32609 - 70L15 Insert shifting 3
32603 – 30P00 Spring shifting 2
All up this list is around $720 trade. There will be other parts including seals etc so i'll update as the rebuild continues.
A Little off topic.
Would anyone know the specific part number for a 1998 GTR box?
I have the number : 32010-12U60. I have googled it but it has returned all sorts of different years.
Is there a such thing as a different number for a 1998 box?
There were 3 boxes...
The early 32 Push type clutch
then the Pull type for the 32
and the Pull type 33.
In short, I don't believe so; it's mostly 33 parts now. Sorry nothing as definitive as youd like I guess
Guys. Could anyone tell me which Nissan dealer they went through the get replacement parts when rebuilding this box. I have spoken to 2 dealers and im not getting anywhere. One dealership told me there is 2 different revisions of the late model 33 boxes.
The parts im after (well having trouble getting) are 1st and 4th synchro's.
  • 7 months later...
