Just wondering if there is a tube header available for the RB20DET with single turbo. Reason I ask is that I was just re-reading A. Graham Bell's "Forced Induction Performance Tuning" (great book btw) and in the practical examples chapter there is an RB20 powered S13 mentioned, and he says the stock turbo would be able to do better than it does now if it had a proper tube header - he seems to think the stock manifold is very restrictive.
J
https://www.sau.com.au/forums/topic/22176-rb20det-tube-header/
It is particularly bad. Worse than the RB25DET. Theres good gains to be had in this area on RB20's, alot of people dont seem to think about it.
Theres plenty of exhaust headers (or "bag of snakes" as some of us refer to them) available for the RB20, depends on what you want to pay. Its worth going with a decent brand name simply so you can be sure of a good fit.
I just looked through Option magazine and converting the yen price alone, most brands seem to be around the 1000-1500 mark. You could no doubt get one made locally a bit cheaper, but the jap stuff does fit well.
Red17
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
