Just wondering if there is a tube header available for the RB20DET with single turbo. Reason I ask is that I was just re-reading A. Graham Bell's "Forced Induction Performance Tuning" (great book btw) and in the practical examples chapter there is an RB20 powered S13 mentioned, and he says the stock turbo would be able to do better than it does now if it had a proper tube header - he seems to think the stock manifold is very restrictive.
J
https://www.sau.com.au/forums/topic/22176-rb20det-tube-header/
It is particularly bad. Worse than the RB25DET. Theres good gains to be had in this area on RB20's, alot of people dont seem to think about it.
Theres plenty of exhaust headers (or "bag of snakes" as some of us refer to them) available for the RB20, depends on what you want to pay. Its worth going with a decent brand name simply so you can be sure of a good fit.
I just looked through Option magazine and converting the yen price alone, most brands seem to be around the 1000-1500 mark. You could no doubt get one made locally a bit cheaper, but the jap stuff does fit well.
Red17
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
