Snap! Peoples, please help me! A mate and I fitted and wired in an AVCR to my S15 today and when finished tried to start it up, key in and turn = eng cranking but no starting Arrrrrrr! So checked everything again = still not starting, checked the ECU loom and found it wasn't quite plugged in properly on one side so pushed loom on more and tightened the screw tighter = started :D
Then I took it off again LOL and tidied up the wires and put back on = not starting again :huh:
Still ain't starting!!!!!!
Could smell fuel and could see fuel vapor in side the zorst, could it of flooded so bad that it want start?
If so, why would it of flooded that bad?
I double checked all the wires individually going into the loom and all seems good!
Could it have hurt anything besause it wasn't plugged in properly?
I was thinking maybe a fuse is blow or something? Could this be possible?
Edited by Hijacker...
https://www.sau.com.au/forums/topic/221774-ebc-install-now-not-starting/
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
