Skid Pan Day Saturday 16th August
It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of, basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
Meanwhile you could come down for a coffee tomorrow. Details in the events section
sorry dude i forget about the forum sometimes. sent you a pm
