HICAS Diagnostic Procedure
1. Input starting conditions for self-diagnosis.
* Turn ignition switch "OFF".
* Set shift lever to "P" or "N" (A/T) or "Neutral" (M/T).
* Turn ignition switch "ON".
* Immediately start engine.
* Turn steering wheel from left to right (at least 20deg from the neutral position) 5- times or more, then depress foot brake pedal at least 5- times all within 10- seconds after ignition switch has been turned "ON".
2. Input self-diagnosis item.
* Depress and release foot brake pedal.
* Turn steering wheel from left to right (at least 20deg) from the neutral position.
* (M/T model):
Depress clutch pedal and move gear shift lever to any position other than Neutral and return to Neutral. Release clutch pedal.
(A/T model):
Disengage and engage parking brake lever. Move shift lever to any position other than Neutral or Parking and return to Parking.
* Move car at least 3 meters (10ft) forward and proceed at indicated speed of at least 2km/h (1mph) in self-diagnosis mode.
3. The self-diagnosis mode will then appear in the "HICAS" warning lamp.
* When all systems are normal HICAS warning lamp flashes at 0.25 second intervals.
* When there is a system malfunction (there is a nifty diagram here of HICAS lamp pulses. I tried to translate them to words...)
Mode A)
10 short pulses for 5 seconds.
No pulses for 5 seconds.
Nine 2-second interval indicating the system status (18 seconds total).
(short pulse = good, 1 second pulse=bad)
1) HICAS Solenoid R.H.
2) HICAS Solenoid L.H.
3) Fail-Safe Valve
4) (Constantly normal mode)
5) Vehicle Speed Sensor
6) Steering Angle Sensor
7) Steering Neutral Position Sensor
8) A/T: Parking brake sensor
___ M/T: Clutch Sensor
9) A/T: Inhibitor Sensor
___ M/T: Neutral Sensor
** Display repeats until ignition switch is turned "OFF" or 5 min has past.
Mode B)
Lamp on for 5 seconds.
(short (0.1 sec) pulse = good, 1 second pulse=bad)
3) Fail-Safe Valve
Note 1: To change the display mode to "A", turn OFF ignition switch after mode "B" is displayed. When battery is insufficient, mode "B" is displayed.
Note 2: If fail-safe system was operated (fail-safe valve is operating) when ignition switch was turned OFF for the last time, mode A will be displayed. If fail-safe system was not operated when the ignition switch was turned OFF for the last time, mode B will be displayed.
* Canceling the self-diagnosis function
Three methods.
1) By turning the ignition switch off.
2) After self-diagnosis has been operated for ~5 minutes.
3) If the vehicle speed goes over 30 km/h (19 mph).
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/
What is HICAS? And do I have it?
Good question. HICAS is Nissan’s version of four wheel steering. It is an acronym for High Capacity Actively Controlled Suspension. Unlike other Japanese car manufacturers 4WS (eg Honda’s system) HICAS never exceeds +/- 1°. It is designed for high speed response rather than parking manoeuvres.
The system is electro-hydraulic - the ECU in the boot directs a hydraulic actuator at the rear axle to steer the rear wheels using the rearmost suspension links. The result is usually no more than 0.4° of movement. HICAS gives a touch of counter steer before settling with the rear wheel pointing the same way as the front. (Maybe this explains why my Skyline feels so loose on high-speed gravel...) This results in sharp turn-in, and enhanced stability at medium to high speeds.
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-479806
What is SUPER HICAS
Nissan Skyline GT-R has the SUPER HICAS setup.
Aided by computer, Super HICAS enables a tightly-controlled power slide that cannot be implemented by any alternatives.
When attacking a corner, the rear wheels will steer in reverse first in order to sharpen the initial steering response. Then, when sensors sense that the car responds to steering, the rear wheels will steer in the same direction as the front wheels, thus immediately introduces rear-tyre slip which help adjusting the attacking angle. Since the computer is monitoring the whole process, the amount of oversteering is always under check. You need not to be afraid of losing control.
The Super HICAS system was also available on a few S13 models. As you can see htat would make drift that little bit easier.
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-479825
  • 8 months later...
  • 1 month later...
HICAS Diagnostic Mode
There is a HICAS warning light in the instrument cluster. If it comes, on it is indicative of a problem.
R32: Check the HICAS oil level (power steering reservoir in some models, or a remote reservoir accessible from the boot)
R32 and R33: Check all HICAS electrical connections, and if the light remains on, follow the diagnostic below.
Note that having an aftermarket steering wheel fitted without the appropriate HICAS boss adaptor can also cause the HICAS system to show a fault.
  1. Switch ignition off, transmission in neutral or auto in Park.
  2. Start engine
  3. Very quickly (with a couple of seconds), turn the steering wheel left and right about 20 degrees from centre five times, and then pump the brakes five times, then press the brake pedal once more this will enter diagnostic mode.
  4. Drive forwards or backwards about 5 metres at a speed less than 10km/hr, this will enter full diagnostic mode.
  5. The HICAS light in the instrument cluster will be flashing quickly (for normal) or will flash a code indicating any problems.
  6. Long flash = first digit, short flash = second digit.
  7. Diagnostics will return to normal after five minutes, or any speed over 10km/hr,
    or ignition is turned off.
HICAS Diagnostic Codes 1989-1993
1 HICAS solenoid right hand
2 HICAS solenoid left hand
3 Cut off valve
4 Power steering solenoid
5 Vehicle speed sensor
6 Steering angle sensor
7 Neutral position sensor
8 (Auto) Parking brake sensor, (Manual) Clutch sensor
9 (Auto) Inhibitor switch, (Manual) Neutral sensor
HICAS Diagnostic Codes 1993-1999
11 HICAS control unit
12 HICAS motor power supply not present
13 HICAS motor output not present
21 Vehicle speed sensor not present
22 Steering angle sensor not present
23 Steering angle sensor neutral or not present
24 Rear main sensor input not present
25 Rear sub sensor input not present
31 Parking brake sensor input not present
32 (Auto) Inhibitor switch input not present; (Manual) Neutral switch input not present
33 Engine speed signal not present
This information from "The Sky Is The Limit, A Book Of Skyline Stuff"
  • Like 1
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-894684
  • 6 months later...
A couple of questions :(
1) What's the difference (beyond the obvious slight difference in how one enters the mode) between the methods posted by Lozza150 and Greg? Do both methods apply to all Skylines fitted with (Super) HICAS?
2) Using Lozza150's method , does HICAS go in to Mode B by default?
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1130513
  • 1 month later...
ok I am trying to self check this HICAS light fault.... now the question remains, does HICAS work, or is it marketing? votes for removal on the GTR? and did gibbo's race cars have it removed?
will have to run this check, as the light seems to come on on slight corners or hard accelleration....
ideas?
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1198781
Yes, it works insofar as it does turn the wheels. If that's a positive (it makes manevourability at very low speeds easier) or a negative (you never quite know what the car will do when you start to corner) if up to the driver.
The diagnostic mode should tell you exactly what's wrong.
LW.
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1199297
Another 2 cents.. I read somewhere that the hicas light will come on if an aftermarket steering wheel is installed and the steering wheel position sensor is not relocated correctly. If i drive in a straight line (open highway) for a couple of minutes without moving the wheel much , my light comes on and stays on till i turn off and restart the car. I know this is my problem as i have a momo steering wheel. Haven't got around to fixing the sensor yet though :cheers:
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1218128
  • 4 weeks later...
I did the diagnostic and got codes 22 & 23, then as I went back into garage it started flashing quickly (the "good" sign), so I did the diagnostic again and got code 22. BTW I had no probs with the HICAS light before this just did the test out of curiosity.
Are:
big problems for the operation of HICAS?
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1248275
Hey actually maybe it was a wrong code, because I noted in another post somewhere I think that if you don't drive forward (or back) far enough you can get an erroneous code. I tried this test again twice going forward further and got the HICAS light flashing fast saying everything's ok. In any case unless it causes me any probs I'll leave it be.
On a side note - I've noticed people saying they disable HICAS because it develops problems and aussie mechanics never know how to deal with it, but as far as I know the 300zx had Super HICAS and that was delivered locally so Nissan mechanics at least would know how to fix it, and certainly there'd be others who've fixed 300s?
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1249850
It is my understanding that hicas reduces the ability to DRIFT properly as what we are trying to do is loose grip on the tires and therefore DRIFT the rear end about whereas HICAS is trying to steer the tires in a direction that will give more grip according to what the EMS understands what the car is doing.
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1262554
They say (they being the Engineers) SUPER HICAS provides a sharper turn in ... which might help flick the car out faster then help in the control of the steer.
Remember HICAS and SUPER HICAS only move the rear wheels up to a max of 1 degree
Hicas moves the rear wheels on GTST's 0.7 of a degree
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1262663
OK i swear i read that HICAS doesn't even kick in till about 60km/h ??
is this true ?
also was hicas an option or what ?, what percentage of cars that came out of the factory were fitted with hicas do you guys rekon ?
my mates are always dissing my 32gtst cos its got hicas and apparantly it adds like an extra 100kgs is this right ?
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1277339
HICAS is at it's most active at high speeds as it is a high speed stability aid more then true 4WS. Can't see it weighing 100kgs. Most people don't even remove it, just "lock" it for drag duties usually.
is this true ?
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1277773
i hate hicas because i dont understand it..
recently my hicas light is coming on.. and doesnt go away. the only time i have seen my hicas light on is during ignition.. i havent experience hicas before.. when hicas kicks in is the light on the dash lit up? also how do i check that a previous owner hasnt disabled it with a lock kit? and if the hicas fluid needs to be topped up, where do i top it up with and with what? thanks
https://www.sau.com.au/forums/topic/22193-hicas-diagnostic/#findComment-1291117
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
