Hi all,
I also had problems with my HICAS with the light coming on after start up but would go away when you turn ignition off then on again once car warmed up. This occurred around 6 months ago. In the last 2 month the HICAS light would suddenly come on during driving and the steering would go heavy. Any who, it ended up being the HICAS control module. I replaced a leaking capacitor and cleaned up all the corrosive liquid on the PCB. Car is a 93 R33 gts-t.
Hope this helps..
hey..
my hicas light comes on after driving along the highway for any more then about 5-10mins.. doesnt go off until car is turned off. but normal around town type driving it never comes on.. also when its on after driving on hughway the steering doesnt seem to change at all..
any ideas?
Do you have an after market steering wheel?
Have you tried the diagnostics?
Can you replicate the problem every time you are on the highway?
yes i have a "personal" brand steering wheel..
nothing shows on diagnostics..
yes problem happens everytime without fail..
Edited by 02_FNE
It maybe your steering wheel that is causing the problem. Not sure what type of angle sensor used but since the control module is not showing an error code the problem may only be minor. Has this light come up ever since you had the steering wheel replaced?
not sure mate, i got the car with this steering wheel already in it.. as far as my memory recalls its always done it..
i thought it was strange that it doesnt seem to change the actual steering at all..
my understanding is that that brand of steering wheel is a nissan owned company or brand or something along those lines..
There are a few threads on this site that talks about the HICAS light coming up after steering wheel/BOSS has been replaced. I think they also say that it only comes up after long straight driving as is done on the highways. The problem in your car should be easily sorted as the symptom is easily replicated.
Buy!
  • 2 months later...
  • 1 month later...
hey ummm i have a question
my HICAS lights turns on
EVERTYTIME , at the exact distance of 10km or so of driving
i time it the spot where i usually go to work n back home
it always turns on at the same area.
so what's wrong with it?
HICAS isn't really a major problem is it?
cheers.
SAME HERE! no idea what it is though? the diagnostic never works for me. i'm assuming it's the steering angle sensor because i can't enter the diagnostic. i'd assume the steering angle sensor is what puts it in diagnostic mode with the left right turns and the brake pumping. when you exceed 80 k's does your steering wheel turn one way slightly and then correct itself when you go back below 80? mine does. until the light comes on. then it stops...
Steering wheel 'rolling over' at speed (increasing as speeds pass 60kph) is what happened on my car when the steering angle sensor was mis-aligned with the wheels.
If you cant answer the diagnostic mode at all - sounds like your steering angle sensor isn't working though. Do you have an aftermarket boss? Nissan dealers with CONSULT should be able to get into the HICAS diagnostics and pinpoint exactly what's wrong (that's what I did).
  • 3 weeks later...
  • 1 month later...
i did the test on my r32 gtr and i got 4 quick short pulses followed by the hicas light staing on for afew seconds...
then after that i kept my car on and still in the diagnostic mode, and it did 4 quick pulses followed by the hicas light staying on for a few seconds
what did it pick up as been the fault ??
the hicas is giving me the shits i need to sort this out ASAP !!!
hope someone can help me !
thanks
someone have a look at my thread and see if you can offer any advice. much appreciated.
http://www.skylinesaustralia.com/forums/Hi...ng-t312556.html
i'm thinking hicas ecu may be faulty. it has the trademark 3 capacitors with a very slight stain below them that may indicate some previous leakage.
Edited by Munkyb0y
  • 5 months later...
  • 4 weeks later...
Must be a different problem with mine.. it has had the problem since i bought the car (with standard steering wheel) and still has it with my after market one..
might be a dodge connection somewhere..
  • 1 month later...
My problem, which I've had no luck in getting anyone to know what I'm on about:
Sometimes when I turn on my car (not all the time, it didn't do it for around 3 weeks but now it's about every third time I turn it on), the HICAS light stays on. Solid. The whole time it's on, it feels like I have no power steering, eg. the wheel is sluggish and hard to turn.
I've checked fluids. That's all fine there.
I've got a MOMO steering wheel, but the HKB boss kit (HKB = HICAS compliant), so there's no problems there. If there was a problem there, it'd be permanent, not just every now and then.
Anyone got any ideas? I'll be performing a diagnostic this weekend, so I guess I'll post up the results of that then rip the car apart till I can find it. Then lock the damn thing down anyway.
Hey all,
Ive got the same problem where once the HICAS light is on the steering becomes very heavy but after I switch of the car and go to switch it on again all my electrics fail there is a wire that got fixed by an R.A.C man and once i move that around the electrics come back on and there is no more HICAS light on this is only recent and is becoming more frequent.
Im not sure whats going on with the car but if anyone knows of any solutions would be greatly appreciated
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
