where is the speed sensor? it is now causing me grief, is it a different assembly to the cluster or is it built into the cluster itself? can it be repaired
http://www.skylinesaustralia.com/forums/in...howtopic=152998 speed sensor replacement thread
  • 3 months later...
i just tried the test (r33 gts-t m/t) multiple times and the light didnt come on... however i noticed when i pumped the brake my revs lifted.... but i do have an aftermarket steering wheel.. where can i get this adapter and where is it actually in the car??
  • 1 month later...
Any car place like Autobarn, you just want a HICAS compatable boss to suit R33, i think about $70 or something. Its the big round thing your steering wheel bolts to and then u bolt that to the car, two plastic tabs will sit inside it if they havent been broken off. It measures the turn angle of the steering wheel used during HICAS calcs on the R33. R32 is hydraulic on the other hand.
Some people also cut the speed signal wire so the ECU doesnt speed limit the car to 180kph, this will also cause your HICAS to stuff up (used in calcs).
Has anyone tried pulling out the hicas sensors and cleaning the dust off?
If its a/market it could be slightly out of tolerance also???
Edited by Jmaac
  • 1 month later...
hey
i have an r33 skyline, did the diagnostics test thing, it has 1 slow flash, then 3 slightly quicker flashes, then 10 very quick flashes, anyone know wat this means? as the warning light now stays constantly on as of today after driving through a smallish puddle at lunch time, lol
  • 4 weeks later...
  • 1 month later...
just a quick question about the hicas cpu can it be removed.
Yes, its been a while since ive seen it. Its either under your centre console (maybe airbag comp. here?) or under the rear parcel shelf
You will then have the light permanently on the dash unless u pull the whole thing apart to cut a single wire.
You will need to remove the electronic solenoids motors in an r33 or hydralics in an r32 to fit a hicas lock bar which will lock the rear wheels straight
this will not fix the rest of the steering geom. that hicas looks after. It will handle crap but at least the rear wheels are pointing forward.
  • 10 months later...
hey ummm i have a question
my HICAS lights turns on
EVERTYTIME , at the exact distance of 10km or so of driving
i time it the spot where i usually go to work n back home
it always turns on at the same area.
so what's wrong with it?
HICAS isn't really a major problem is it?
cheers.
HICAS Diagnostic Procedure
1. Input starting conditions for self-diagnosis.
* Turn ignition switch "OFF".
* Set shift lever to "P" or "N" (A/T) or "Neutral" (M/T).
* Turn ignition switch "ON".
* Immediately start engine.
* Turn steering wheel from left to right (at least 20deg from the neutral position) 5- times or more, then depress foot brake pedal at least 5- times all within 10- seconds after ignition switch has been turned "ON".
2. Input self-diagnosis item.
* Depress and release foot brake pedal.
* Turn steering wheel from left to right (at least 20deg) from the neutral position.
* (M/T model):
Depress clutch pedal and move gear shift lever to any position other than Neutral and return to Neutral. Release clutch pedal.
(A/T model):
Disengage and engage parking brake lever. Move shift lever to any position other than Neutral or Parking and return to Parking.
* Move car at least 3 meters (10ft) forward and proceed at indicated speed of at least 2km/h (1mph) in self-diagnosis mode.
3. The self-diagnosis mode will then appear in the "HICAS" warning lamp.
* When all systems are normal HICAS warning lamp flashes at 0.25 second intervals.
* When there is a system malfunction (there is a nifty diagram here of HICAS lamp pulses. I tried to translate them to words...)
Mode A)
10 short pulses for 5 seconds.
No pulses for 5 seconds.
Nine 2-second interval indicating the system status (18 seconds total).
(short pulse = good, 1 second pulse=bad)
1) HICAS Solenoid R.H.
2) HICAS Solenoid L.H.
3) Fail-Safe Valve
4) (Constantly normal mode)
5) Vehicle Speed Sensor
6) Steering Angle Sensor
7) Steering Neutral Position Sensor
8) A/T: Parking brake sensor
___ M/T: Clutch Sensor
9) A/T: Inhibitor Sensor
___ M/T: Neutral Sensor
** Display repeats until ignition switch is turned "OFF" or 5 min has past.
Mode B)
Lamp on for 5 seconds.
(short (0.1 sec) pulse = good, 1 second pulse=bad)
3) Fail-Safe Valve
Note 1: To change the display mode to "A", turn OFF ignition switch after mode "B" is displayed. When battery is insufficient, mode "B" is displayed.
Note 2: If fail-safe system was operated (fail-safe valve is operating) when ignition switch was turned OFF for the last time, mode A will be displayed. If fail-safe system was not operated when the ignition switch was turned OFF for the last time, mode B will be displayed.
* Canceling the self-diagnosis function
Three methods.
1) By turning the ignition switch off.
2) After self-diagnosis has been operated for ~5 minutes.
3) If the vehicle speed goes over 30 km/h (19 mph).
hi i did mannual conversion on auto r33 gtst and steering wheel goes heavy???????? why????
  • 1 month later...
Does this work with an aftermarket ecu...
I have a Haltech E11v2 and couldn't get this to work.
Just tried it with the standard ecu aswell and couldn't get it to work... must be doing something wrong...
just to clarify that you center the steering wheel to start with then turn it to the right at least 20 degrees, then back to center - repeating 5 times
Brake 5 times
All within 10 secs
Then brake again
turn wheel again
clutch in, into gear, then out
then diagnostic mode is suppose to start...
Edited by axe s
Hi,
My HICAS light decided to come on today while driving and hasn’t turned off after unplugging all plugs and fuses and connecting everything back up, HICAS light still stays on. So I ran the Diagnostics only to find a heap of flashes that I can match to both different guides on the first page but both give different results...
Here is what i got from the Diagnostics
Long, Short, short, Long, long, short, long, long, short, Extra long flash where it the starts again...
Can anyone help on this??
Regards,
Ed
  • 2 months later...
  • 3 weeks later...
A new problem for the thread, I read through the replies and can't find a symptom/problem like mine. I'm pretty sure I know what it is, but want to check. When I got my car, after about a week, it split a hydraulic line and leaked out fluid and I had to get it repaired. I'm pretty sure that I didn't have any problems with it before then (But it's so long ago, I can't remember), but I think when the mechanic topped it back up; they didn't bleed the system and might have even put in a different viscosity/type of fluid into the system. The light will flash every now and again; but it gets a lot worse in hot weather than in cold (Engine heat soak seems to affect it too) and it feels like the pump 'skips' every now and again; like there's a difference in the viscosity in the fluid or it's coming across a bubble in the line. The steering will load up occasionally in a corner; with no power assistance at all, then it'll jerk and I'll have power assistance again and the light will flash whenever the system 'hiccups' like this. And yes, I check the fluid resevoir regularly with the engine on; it never leaks and is always between the marks. How hard is it to completely bleed and refill the system? I'd appreciate it if anyone can help. '89 R32 GT-R. I'm going to do a full fluids service on it as it is and if this doesn't solve the problem, I've got a lock-off bar and rods that I'll use instead, to be lazy. If someone could point me in the direction of a DIY guide of bleeding, it'd be great. I can't do a diagnostic because the car's not driveable at the moment.
Edited by Fennec
I haven't tried the test, but my HICAS light only comes on once I'm going about 100km/h or over.
That seems very strange to me. As soon as I turn the car off and back on it goes away and it never comes up while city driving.
Edited by offroadaaron
hay mate
i have the same any ideas
  • 2 months later...
my hicas light comes on reliably after about 15 min of driving,
when driving to trade school it always comes on at about the same bit of road in my route,
i have tried entering diagnosis mode but it doesnt work, am i not doing it right?
This is what i do
ignition off
car in neutral,
start car
turn wheel left and right vigourously about 5-6 times,
pump brake pedal fairly quickly 5-6 times.
put clutch in and go into first gear, and then back to neutral and release clutch
nothing hapens..
car is a 1989 hcr32 gtst
am i missing something?
i also tryed driving forwards 5 metres, n it didint work
This is what i do
ignition off
car in neutral,
start car
nothing hapens..
I have the same 2 problems... mine comes on about 15 mins of driving
and i can't get the diagnostic to work...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
