Hi all,
I also had problems with my HICAS with the light coming on after start up but would go away when you turn ignition off then on again once car warmed up. This occurred around 6 months ago. In the last 2 month the HICAS light would suddenly come on during driving and the steering would go heavy. Any who, it ended up being the HICAS control module. I replaced a leaking capacitor and cleaned up all the corrosive liquid on the PCB. Car is a 93 R33 gts-t.
Hope this helps..
hey..
my hicas light comes on after driving along the highway for any more then about 5-10mins.. doesnt go off until car is turned off. but normal around town type driving it never comes on.. also when its on after driving on hughway the steering doesnt seem to change at all..
any ideas?
Do you have an after market steering wheel?
Have you tried the diagnostics?
Can you replicate the problem every time you are on the highway?
yes i have a "personal" brand steering wheel..
nothing shows on diagnostics..
yes problem happens everytime without fail..
Edited by 02_FNE
It maybe your steering wheel that is causing the problem. Not sure what type of angle sensor used but since the control module is not showing an error code the problem may only be minor. Has this light come up ever since you had the steering wheel replaced?
not sure mate, i got the car with this steering wheel already in it.. as far as my memory recalls its always done it..
i thought it was strange that it doesnt seem to change the actual steering at all..
my understanding is that that brand of steering wheel is a nissan owned company or brand or something along those lines..
There are a few threads on this site that talks about the HICAS light coming up after steering wheel/BOSS has been replaced. I think they also say that it only comes up after long straight driving as is done on the highways. The problem in your car should be easily sorted as the symptom is easily replicated.
Buy!
  • 2 months later...
  • 1 month later...
hey ummm i have a question
my HICAS lights turns on
EVERTYTIME , at the exact distance of 10km or so of driving
i time it the spot where i usually go to work n back home
it always turns on at the same area.
so what's wrong with it?
HICAS isn't really a major problem is it?
cheers.
SAME HERE! no idea what it is though? the diagnostic never works for me. i'm assuming it's the steering angle sensor because i can't enter the diagnostic. i'd assume the steering angle sensor is what puts it in diagnostic mode with the left right turns and the brake pumping. when you exceed 80 k's does your steering wheel turn one way slightly and then correct itself when you go back below 80? mine does. until the light comes on. then it stops...
Steering wheel 'rolling over' at speed (increasing as speeds pass 60kph) is what happened on my car when the steering angle sensor was mis-aligned with the wheels.
If you cant answer the diagnostic mode at all - sounds like your steering angle sensor isn't working though. Do you have an aftermarket boss? Nissan dealers with CONSULT should be able to get into the HICAS diagnostics and pinpoint exactly what's wrong (that's what I did).
  • 3 weeks later...
  • 1 month later...
i did the test on my r32 gtr and i got 4 quick short pulses followed by the hicas light staing on for afew seconds...
then after that i kept my car on and still in the diagnostic mode, and it did 4 quick pulses followed by the hicas light staying on for a few seconds
what did it pick up as been the fault ??
the hicas is giving me the shits i need to sort this out ASAP !!!
hope someone can help me !
thanks
someone have a look at my thread and see if you can offer any advice. much appreciated.
http://www.skylinesaustralia.com/forums/Hi...ng-t312556.html
i'm thinking hicas ecu may be faulty. it has the trademark 3 capacitors with a very slight stain below them that may indicate some previous leakage.
Edited by Munkyb0y
  • 5 months later...
  • 4 weeks later...
Must be a different problem with mine.. it has had the problem since i bought the car (with standard steering wheel) and still has it with my after market one..
might be a dodge connection somewhere..
  • 1 month later...
My problem, which I've had no luck in getting anyone to know what I'm on about:
Sometimes when I turn on my car (not all the time, it didn't do it for around 3 weeks but now it's about every third time I turn it on), the HICAS light stays on. Solid. The whole time it's on, it feels like I have no power steering, eg. the wheel is sluggish and hard to turn.
I've checked fluids. That's all fine there.
I've got a MOMO steering wheel, but the HKB boss kit (HKB = HICAS compliant), so there's no problems there. If there was a problem there, it'd be permanent, not just every now and then.
Anyone got any ideas? I'll be performing a diagnostic this weekend, so I guess I'll post up the results of that then rip the car apart till I can find it. Then lock the damn thing down anyway.
Hey all,
Ive got the same problem where once the HICAS light is on the steering becomes very heavy but after I switch of the car and go to switch it on again all my electrics fail there is a wire that got fixed by an R.A.C man and once i move that around the electrics come back on and there is no more HICAS light on this is only recent and is becoming more frequent.
Im not sure whats going on with the car but if anyone knows of any solutions would be greatly appreciated
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
