  • 1 month later...
my hicas light comes on reliably after about 15 min of driving,
when driving to trade school it always comes on at about the same bit of road in my route,
i have tried entering diagnosis mode but it doesnt work, am i not doing it right?
This is what i do
ignition off
car in neutral,
start car
turn wheel left and right vigourously about 5-6 times,
pump brake pedal fairly quickly 5-6 times.
put clutch in and go into first gear, and then back to neutral and release clutch
nothing hapens..
car is a 1989 hcr32 gtst
am i missing something?
i also tryed driving forwards 5 metres, n it didint work
Your missing 1 step according to your steps above.
Easier steps to understand is:
1- car is off, transmission in Neutral and steering wheel is dead center.
2- turn key to accessory, when ready turn car on.
3- with steering wheel dead center (imagine a white line in center of steering wheel)
turn to the right so that the line moves about 20cm - now turn to the left about 40cm (that is considered 1). turn to the right about 40cm and back to the left 40cm (that is considered as 2) repeat up to six times.
4- push and release brake peddle 6 times
5- turn steering wheel to right 20cm than to the left 40cm than to the right 20cm (so it's now back in the center)
6- push clutch in move lever into gear than out of gear, now release clutch
7- now stare at hicas light and count the flashes.
that's it takes, for reference it takes me about 5 seconds to do all of above (steps 1 to 6).
with step 7- if it starts with 10 quick flashes means your in mode A, if there is a long 5 second flash means your in mode B, after that now count flashes and refer to op for what it means.
hope this helps.
  • 2 years later...
I know this is an old thread, but figured this is the best place to ask the question. Which loom dose the wires to the steering rack pressure solonoid attach to? Or perhaps tell me the colours of the wires on the loom that it attaches to? After investigation I found on my car it's not attached to anything.
  • 1 year later...
Hi Guys
Recently just got my car back, 95 r33 gtr vspec. was getting eflex and tune after couple new parts.
Driving home I was getting a bit of a sway or wobble in the rear, felt like the rear. So took it easy it was only when I went over a rise or bit of a bump in a dip. Ive had shot suspension before and definitely didn't feel like that.
So checked all wheel nuts when I got home, all good and tight. went down to pump up tires as they were a little low, 15psi then what I would usually have them. went for a drive felt good. gave it a little and the wobble was back. Pulled over and had a quick look under. all nuts and bolts where there and seemed good.
Got home and jacked it up, gave it a once over. Found that I could move the passenger side wheel to the left and right, well left and back again, about 2mm or so. Driver side is all tight no movement. The movement seems to be coming form the join at the steering rack. The tie rod doesn't have movement anywhere.
My questions are, am I right in assuming that there should be no movement at all, and this is what could be giving me the "wobble".
if so, are there any bushes I can replace rather then the rack itself, as the exploded diagram from Nissan doesn't have anything apart from rack, and the tie rods, covers and what not. or an over haul kit or something of the like.
Has anyone else had an issue like this and should I just put a hicas lock bar in as most likely cheaper. Also is it just a simple job as the 33 is elec rather then the hydraulic one on the 32s.
thanks for any help you guys can offer. any pics also to reference would be appreciated.
cheers guys
  • 5 years later...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
