Hello!
I have a 1992 GTS-t that I've imported from Japan, and this issue is starting to drive me nuts. I've tried a lot of different things from this forum, and others that I've found using search, but I still haven't figured it out yet.
My car hesitates...it's mostly present once the car is fully warmed up and has been driven a while. It mostly happens when accelerating, or going up a hill, or around a corner. It isn't a slight loss of power, it's like ALL power is GONE for 1-2 seconds. Sometimes it will even start to buck as power cuts in and out during that few seconds. I find it is typically OK when just cruising at a constant speed, but as soon as I come to a light, and accelerate, go around a corner, up a hill etc, it *occasionally* happens.
This is what I've done so far:
- fuel filter was tough to blow through, so I replaced it (this fixed the stalling issue I had)
- Replaced fuel pump with a SARD 265 l/m (tank appears quite clean)
- New coil harness
- coils appear to be in good shape
- new sparks
- new ignition module (this fixed a "different" hesitation I was also having)
- new Optima battery (will be redoing the ground once my terminals arrive)
- cleaned AAV valve (idled like poo and it was quite dirty) and set idle to 950ish. The solenoid still whines a bit though...
- tested different MAF, didn't change anything
I'm starting to run out of ideas...
I'm going to try a different CAS just to see...I will do that in the next few days...
I'm also thinking it may possibly be the fuel regulators?
Or EGR is messing up?
Would a buggy AAC solenoid be capable of causing this hesitation?
I'm really not sure anymore. I'm going to check for codes when I can find the time to get it tested. But I'm just wondering if someone has some fresh ideas, or a different perspective to help me out.
cheers :D
have you checked your fuel pump wiring... just a thought... might be cracked and earthing when you turn etc...
The wiring in the trunk and to the pump appears to be in decent condition. Are there common areas where this would happen? I will double check to be certain though..but from what I saw when replacing my pump, everything was OK.
Thanks though! :teehee:
This week I'm replacing the main ground with a 4gauge wire, and then a few other chassis and block grounds with 5-6 8gauge connections. I will also check other grounds to assess their condition as well...
Also, a friend of mine shorted out my battery and fried it (hence the new optima battery) when he was helping me jump the car. Fried my main 75amp fuse, and now my tail lights and dash lights are not working (all other interior and exterior lights are fine)...but all the other fuses appear to be ok? grr...that's all I needed with this other stuff...
I can figure that out later...I just want to fix this hesitation so I can take my car more than 10 KM's without it starting to jerk in a massive car-orgasmic kind of way...
did you get the pump rewired correctly something about r32's not having enough volts to run the pump properly so you get it rewired anyway this is where i would be looking hows ur coil packs u did not mention them.?
cheers
Allan
get it on the dyno and try to recreate the hesitation and see what the results are
might make it easier to diagnose
what mods have you got?
check your Throttle position sensor (tps) voltage. its around 0.4v closed and 4v fully opened
check your ecu for any error codes
do you have any leaks in the intercooler piping? or anywhere else on the intake side for that matter
Try running some injector cleaner
is there any boost surge?
is it just a hesitation or does it miss as well when it does it?
What happens when you drop a gear and put your foot down?
cheers
Allan
Thanks Allan
Coil packs appear in good shape. I've tried another set and same thing.
Pump is rewired correctly. All the wiring appeared to be in good shape.
Thanks man. My last resort is taking it in to get checked. I wanted to try my own stuff first to try and save some cash. I had it into one shop and all they told me was one cylinder was a bit low on compression, but I do not believe low compression on just 1 cylinder would cause this issue.
TPS is good. It's been adjusted to 0.48v and then appears to be fine to fully open right around 4v.
I'm in the process of trying to find someone locally here that will check the error codes for me.
I will double check for leaks. I didn't see any previously.
I've ran cleaners
The car was overboosting. A new actuator helped, but it still gets to 1bar (as opposed to 1.2bar) on my apexi boost gauge. But on the stock gauge it doesn't read that high so I've skeptical on that 1 bar...I forgot to mention that.
The care is pretty much stock. I just have an apexi power intake, and now a SARD pump.
When I drop and gear and lay into it, there typically isn't any problems. It would be more likely to hesitate AFTER I lay my foot into it. If I give'er after a light, and then after I slow down, and then accelerate normal, it has hesitated then moreso.
And it just hesitates...its like all power is completely gone. Sometimes it comes back right away if I blip my foot on the gas, but sometimes it will also start convulsing (usually only after it's driven for a longer distance). So I don't really think it is 'missing' because its not like I loose a little bit of power, it's like the car is coasting in gear.
:thumbsup:
I was wondering about the knock sensors myself...Would they cause this type of powerloss/hesitation if faulty?
I've inspected the AFM and everything seems to be in order...
I went through all my fuses this afternoon, and actually found more than just my tail light fuse was dead.
http://www.skylinegts.co.uk/R32-Fuses.htm
My shift lock fuse was also burnt - what the heck does this do?
you can check the error codes yourself
http://www.skylinesaustralia.com/forums/EC....html&st=20
Do that and look for the flashing light on your dash. Long flash = first number, short flash = second number eg: - - - . . . = 33 if that makes sense
ECU Diagnostic Codes
11 Crankshaft position sensor
12 MAF sensor circuit (air flow meter)
13 Coolant temperature circuit
14 Vehicle speed sensor circuit
21 Ignition circuit
31 ECU (ouch!)
34 Knock sensor
43 Throttle position circuit
45 Injector leak
51 Ignition circuit
54 Auto signal to ECU
55 All OK
Turn the ignition off to put the ECU back to normal.
Edited by r32woohoo
Thanks for the link man.
Here is some pictures if anyone searches and finds this thread for future reference...
http://www.skylinesaustralia.com/forums/in...t&p=3723574
I'm going to go out and try this when it stops raining...
That would be brilliant if it's something came up that I haven't checked yet...
I really need this car working because I start a new job in emerg (I'm a nurse) so it is going to be a real buggar to take the bus...a 30 minute trip becomes 1.5 hours...
Ok, wow, should have known about this a while ago...
I'm getting a few errors.
34 Knock sensor
I do have a custom ECU so I'm not sure if 54 is relevant? But the other 2 would make sense.
can't seem to edit my posts...sorry for double posting so much,
But the #54 I have confirmed is a normal code for this ECU...
Anywhoo, I will order a knock sensor, and take a closer look at my MAF and go from there...
Are they easy to replace?
yet another afterthought here...
The hesitation seems to be worse when it is a rainy day. So maybe the MAF is indeed fooked. a little moisture in the air, and it starts to hesitate much sooner than if it was a normal sunny day. I can go about 2km's to get groceries just fine with maybe one or two very short hesitations coming home, but when it's rainy outside, I can't even make it to the store without having quite larger and longer hesitations where there is no power...and it's mostly right after I stop at a light so it takes a very fast car, a very LONG time to get up to speed because my car is having a mini orgasm while I'm trying to accelerate.
I was thinking before that maybe my fuel regulator wasn't regulating well, but I think I would still have SOME power there, instead of an all out CUT in power. So I'm moving away from that idea...
I'm pretty sure I don't hear any knocking. But who knows, maybe my low cylinder could cause a knock sensor to wig out? OR, it's just a faulty knock sensor, and when it wigs out, it cuts power to my car for a brief time?
I have a friend with a different MAF that I'm going to borrow. The ECU should be reset now after the diagnostic mode was shut off, so I'm curious to see if that will come back...then it would be the wiring and I can take some volt readings at the ECU to see if my wiring is bad. I will also inspect the plugs.
Any thoughts/opinions/ideas would be appreciated. This is my first RB and so far it's been a royal pain in the ass, but I do have a basic understanding of how it all works... Thanks for the help thus far~!
They do tend to become a major pain in the ass but it makes it all the more enjoyable when you fix it
But anyway, I dunno about the knock sensor but the afm error makes sense.
You might just have a loose connection in the afm, theres a diy thread on how to re-solder the joints, try that.
I would say MAF straight away. Mine used it loose all power randomly(as in felt like engine turned off) could be for 1.2 a second or for 3.
Replaced MAF and all good
Dude, you have no idea how happy I would be if that was it. I tried this earlier, but there were other problems with my ignition system causing a different sort of hesitation...so I probably overlooked this issue.
I have a buddy with a spare MAF, I'll give it a go tomorrow after I inspect the condition of the soldering done to my current MAF.
I feel like a real dummy because I knew the MAF was a common problem in these cars, but I had tested the other one before, and I was still having problems, but as I mentioned, that was from something else (ignition module) and now after resoldering the MAF I went out for 30 minutes and didn't experience the nasty hesitation. I will pray that fixed it...but I wont be sure until a few days...
Should I also replace my knock sensor if the ECU was pulling that code? Maybe it would help my mileage if it is bad...
I will drive more later in the day...
I was also wondering if a bad MAF would also cause the engine to detonate...bad air/fuel ratio causes it to get too hot, and detonate? Just curious...because I had some earlier. Sounded like crunching tin foil under water...but I didn't hear it now when I would be in full boost, approaching the redline (when I would hear it before)..
Edited by Chris_RB
its always the tps.
TPS? That was one of the first things I checked. Set it to .48ish and then it is quite an even climb to 4v fully open.
I drove the car quite a lot tonight without a problem. Also, after cleaning the AAC valve the other day, the idle is PINNED at 1K (I set it a bit higher because I like it better than even 900-950). It used to jump all over, and stall out too (which I think resoldering the MAF took care of).
I will pull codes again in a few days to see if the knock sensor is still coding.
But I got on a highway tonight, and FINALLY I can feel nice pull right up to 180+ without any problems. I can also stop at a light without fearing if I'll make it through the intersection...lol...this is what I bought the skyline for - to enjoy my driving experience and that just started tonight... :)
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
