i have had my skyline r33 for about 10months now n since i never had any problems with my battery and my sound system, but about 4weeks ago it started to die out so i bought a new battery, which has 2yr warranty. but within few hrs after driving the car wont start... either the alternator wont charge the battery or the my sound system has drain the battery fast!!
i also did some experiment with the amp, when i unplugged the amp from the battery the car has enough power to start but when its plugged it has to b jumped started. does this mean the amp is taking to much power? or the battery is dead? i drive around 20-50kms a day wouldnt that charge the battery enough?
and also every morning when im about to go to work the battery is dead again! so i have to jump start it again!
what seems to be the problem? alternator wont charge? loose cable? the amp? or dodgy wiring on the sound system?
plz help guys :P, thanks
I
https://www.sau.com.au/forums/topic/221980-car-battery-keeps-dying-out/
get a volts meter
my mechanic lives like 4 houses up from me so im lucky but he puts the volts meter on the lugs (when my battery was bothering me) and it will tell you the current the alternator is feeding
all you have to do is have to car running and know your readings on the volts meter to read the alternator
if its not that go to supercheap and they do a battery test for free
i know its a long shot but if its a bosch battery i sware 1 in 20 of them are screwed from scratch
black gtst has my problem
my amp has a switch too ill the power when the car is off but it still sucks the power so i pull my fuse out everytime the car is turned off for more than 3 days
plz help guys :P , thanks
I
This could mean a few of things.
Either your alternator is on its way out and not maintaining the batt (An alternator only surface charges a battery and does not charge a very low battery to its maximum) or
Above + a battery that has been sitting around in a shop can and will loose charge if not maintained. Installing in a car with a faulty alternator will produce your fault.
You may have a problem with your amplifier drawing too much current due to a fault (I have seen this on an amp before)
Check the voltage across the batt terminals while running. If it checks out 13.9V - 14.7V, disconnect the amp from the battery and take your car for a really good run and see how it goes starting the next morning. If it does start, try your sound system next.
There could be another fault causing this but that's where i would look first.
I have the same problem, currently going to replace my old (from 2001) head unit, and get someone to rip out my amp and rewire everything properly.
my mech got his auto elec to check it out and yes, it was the stereo/amp that was draining new batteries after a week.
  • 1 year later...
Huh i currently have the same problem aswell but it only started after i put in an aftermarket piggy back comp for the car! It ran like crap when i put it in so i took it out and since then i loose my battery over night!!! Now i did a few simple tests and have found out (so far) that my car is actually running a positive charge from the ground in the boot to the negative terminal!!!!!!!!! FU**S me as to how that works but a few people have told me that it could be a stuck solanoid somewhere or even a realy bad earth first place to look is the cars cigarette lighter as that is one of the biggest current drawers in it!
I disconected my amps and stereo and upgradded my earthing strap and it seems to be doing the trick so here hopes all is good!!!! :P
I disconected my amps and stereo and upgradded my earthing strap and it seems to be doing the trick so here hopes all is good!!!! :thumbsup:
If this was the case it would have started an electrical fire. or it would have fried most of the electricals in the car and it simple would not run or do much at all.
A really bad earth will not drain your battery at all.
A stuck soleniod? in what? you can rule that out as causing your dead battery.
You probly had an issue with your stereo drawing to much current while off too.
To check your battery,
You'll need a mult-meter. These checks are all taken at the battery terminals.
1. check the static voltage (no load) should be between 12.5 - 12.8 volts
2. check under load (cranking) should not drop under 9v
3. check Alt while charging (running) should be 13.6 to 14.3 volts
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
