well we agreed it was time to stop hijacking Russ' thread, so here is one of our own.
having built and raced standard gtrs for a couple of years (well couple of minutes track time), we figured it was time to go the other way and build something a bit more over the top. but of course our budget hasn't expanded so this is all being done on the dirt cheap (as usual). Hopefully under $20k over a couple of years - will see how we go on that. we've had it for about 18 months now but have only really got going this year
step 1. cheap shell that someone had to sell.
dead standard just a white car with a bit of paint.
https://www.sau.com.au/forums/topic/221982-mark-and-duncans-r32-build/
we don't really have a good pic but the rear parcel shelf has been cut out too. you can see it in the roll cage pics.
speaking of which....Mark has been working on the cage for weeks. thankfully with rob who knows what he is doing lol
it looked roomy back there for a while without the parcel shelf.
plenty of bracing, cross bracing and even support for the subframe mounts. don't think we'll need a rear strut brace now
front of the cage was a bit trickier. we wanted to support the front strut tower properly so we had to loose the
brake booster
abs
wiper motor
clutch master resoviour
brake lines
i guess some of those things will go back in somewhere later (1, 4 and 5 hopefully)
its a bit close to the throttle inside but other than that looks great. and all the holes in the firewall have been welded up to. and the speedo cable hole so i guess we wont be having one of them lol
we've braced the cage to the a and b piller in 4 places too
heres the side of the cage. could be tricky to get out in a rush
which also kind of gives away the minor mods to the doors
they are getting ally skins once the windows are in - although i think we might have gone a little too far around the hinges - they flex so much the paint has cracked. might need to start again with them.
about 2k spent on that materials and labour probably. and a absolute heap of work
up next.....clean and paint the cage and interior to protect it all.
also no pics but we've made a boot out of the ally sheet as well, rob did a top job welding such thin material. need to do some final adjustments then fit it up with some bonnet pins
also - foam filling. you can kind of see in the second pic, the a pillar and sills have been foam filled. one side only so far, need to finish off the other side soon.
also - all the wiring is out, we will pull out everything we don't need which will be at least 50% of it. its damn heavy and there are 4 seperate looms in the car.
windows are all gone, we are putting in perspex instead. looks pretty easy to form to shape but we haven't got there yet so who knows.
have a motor waiting to go on a stand, only 2.6 but got all the good stuff inside and a fair bit of work to the head including big cams. all the stuff we aren't allowed to do to the productions cars. was pretty cheap we had pretty much everything around.
from here its mostly stuff we have to spend money on, so that will decide how quick we can do it.
fuel system
shocks springs swaybars
bushes and adjsutable arms
big wheels - no more of this standard 17x8 shit
brakes
tyres
tailshaft
seat, harness, kill switch, extinguisher
A great thread - been looking forward to his as im doing an almost identical setup and im at a very similar stage.
Jaon - The 18" tyres are the best value for money (along with 16") the slicks are only slightly more expensive too.
cool thread great to see mate!
hehe i bet it feels great to be able to throw the rule book away and do what you want and in some ways sometimes that is cheaper.
bigger wheels = bigger brakes
firewall mod looks good too!!
are you doing some seam welding?
cheers russ
yawn - it will be log booked as a sports sedan like russ' one, one of only 3 gtrs with a 3D logbook afaik. but probably wont race, there isn't enough metal left to rub panels with anyone.
jas - no way will it be ready for this superlap, probably 3-6 months away from hitting the track atm and probably 12 months until it is sorted properly. We've built enough cars now to know these tings take way longer than you plan unless you can just pay a workshop to do it all.
will probably go 18s so we can use larger than targa brakes like g4s on 355mm rotors. and also can use porsche cup slicks for practice, and there are plenty of 18" slicks to choose from these days
russ....we have been talking about it, and I guess thats the reason for the thread - to think about those things. have you given it a go and where in particular were you think of? front struts still seems the weakest to me
yep front struts towers, the area under your front guards along the seams there, also there is a little triangular plate there weld that fully too or make a more solid one.
may as well while you've got the welder out before painting.
cmon russ there are pics, you need to add circles so i get it :P
andrew - rear firewall is required between the cabin and the fuel tank/system. but they will probably end up under the car not in the boot. pretty much where the standard tank goes. we can get fuel cells at a very good price from austalian auto. and lets face it the standard parcel shelf is not exactly fireproof. If we need to put something back it will be a sheet of ally rear of the strut towers
ben
1 - no lol. mark might have the numbers. but there were heaps.
2 - probably normal 4" for now we have one around. i saw the trouble russ has had with his so I am thinking rear titanium. side is fine in the production car where we only need twin 60mm. but i think this one will need to breathe a bit better than that. we still have to make some decisions around turbos/manifolds/dumps yet.
3 - gone and never coming back. we are keeping the brake booster though - i have driven a gtr on the track without the booster and it was a disaster.
4 - proably will go dash pad and cluster at first, but something custom later. don't have $1k to spend on gauges atm...
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
