well we agreed it was time to stop hijacking Russ' thread, so here is one of our own.
having built and raced standard gtrs for a couple of years (well couple of minutes track time), we figured it was time to go the other way and build something a bit more over the top. but of course our budget hasn't expanded so this is all being done on the dirt cheap (as usual). Hopefully under $20k over a couple of years - will see how we go on that. we've had it for about 18 months now but have only really got going this year
step 1. cheap shell that someone had to sell.
dead standard just a white car with a bit of paint.
https://www.sau.com.au/forums/topic/221982-mark-and-duncans-r32-build/
we don't really have a good pic but the rear parcel shelf has been cut out too. you can see it in the roll cage pics.
speaking of which....Mark has been working on the cage for weeks. thankfully with rob who knows what he is doing lol
it looked roomy back there for a while without the parcel shelf.
plenty of bracing, cross bracing and even support for the subframe mounts. don't think we'll need a rear strut brace now
front of the cage was a bit trickier. we wanted to support the front strut tower properly so we had to loose the
brake booster
abs
wiper motor
clutch master resoviour
brake lines
i guess some of those things will go back in somewhere later (1, 4 and 5 hopefully)
its a bit close to the throttle inside but other than that looks great. and all the holes in the firewall have been welded up to. and the speedo cable hole so i guess we wont be having one of them lol
we've braced the cage to the a and b piller in 4 places too
heres the side of the cage. could be tricky to get out in a rush
which also kind of gives away the minor mods to the doors
they are getting ally skins once the windows are in - although i think we might have gone a little too far around the hinges - they flex so much the paint has cracked. might need to start again with them.
about 2k spent on that materials and labour probably. and a absolute heap of work
up next.....clean and paint the cage and interior to protect it all.
also no pics but we've made a boot out of the ally sheet as well, rob did a top job welding such thin material. need to do some final adjustments then fit it up with some bonnet pins
also - foam filling. you can kind of see in the second pic, the a pillar and sills have been foam filled. one side only so far, need to finish off the other side soon.
also - all the wiring is out, we will pull out everything we don't need which will be at least 50% of it. its damn heavy and there are 4 seperate looms in the car.
windows are all gone, we are putting in perspex instead. looks pretty easy to form to shape but we haven't got there yet so who knows.
have a motor waiting to go on a stand, only 2.6 but got all the good stuff inside and a fair bit of work to the head including big cams. all the stuff we aren't allowed to do to the productions cars. was pretty cheap we had pretty much everything around.
from here its mostly stuff we have to spend money on, so that will decide how quick we can do it.
fuel system
shocks springs swaybars
bushes and adjsutable arms
big wheels - no more of this standard 17x8 shit
brakes
tyres
tailshaft
seat, harness, kill switch, extinguisher
A great thread - been looking forward to his as im doing an almost identical setup and im at a very similar stage.
Jaon - The 18" tyres are the best value for money (along with 16") the slicks are only slightly more expensive too.
cool thread great to see mate!
hehe i bet it feels great to be able to throw the rule book away and do what you want and in some ways sometimes that is cheaper.
bigger wheels = bigger brakes
firewall mod looks good too!!
are you doing some seam welding?
cheers russ
yawn - it will be log booked as a sports sedan like russ' one, one of only 3 gtrs with a 3D logbook afaik. but probably wont race, there isn't enough metal left to rub panels with anyone.
jas - no way will it be ready for this superlap, probably 3-6 months away from hitting the track atm and probably 12 months until it is sorted properly. We've built enough cars now to know these tings take way longer than you plan unless you can just pay a workshop to do it all.
will probably go 18s so we can use larger than targa brakes like g4s on 355mm rotors. and also can use porsche cup slicks for practice, and there are plenty of 18" slicks to choose from these days
russ....we have been talking about it, and I guess thats the reason for the thread - to think about those things. have you given it a go and where in particular were you think of? front struts still seems the weakest to me
yep front struts towers, the area under your front guards along the seams there, also there is a little triangular plate there weld that fully too or make a more solid one.
may as well while you've got the welder out before painting.
cmon russ there are pics, you need to add circles so i get it :P
andrew - rear firewall is required between the cabin and the fuel tank/system. but they will probably end up under the car not in the boot. pretty much where the standard tank goes. we can get fuel cells at a very good price from austalian auto. and lets face it the standard parcel shelf is not exactly fireproof. If we need to put something back it will be a sheet of ally rear of the strut towers
ben
1 - no lol. mark might have the numbers. but there were heaps.
2 - probably normal 4" for now we have one around. i saw the trouble russ has had with his so I am thinking rear titanium. side is fine in the production car where we only need twin 60mm. but i think this one will need to breathe a bit better than that. we still have to make some decisions around turbos/manifolds/dumps yet.
3 - gone and never coming back. we are keeping the brake booster though - i have driven a gtr on the track without the booster and it was a disaster.
4 - proably will go dash pad and cluster at first, but something custom later. don't have $1k to spend on gauges atm...
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
