cmon neily send those pics over. I love the way they made the rear arm mounts adjustable, we will go that way for sure.
Andrew....you aren't selling yours are you :) any car you change to from a GTR will disappoint you....
i would like the money at the moment, i want to start a business venture and need atleast 32k. and was hoping to buy the car back a few months down the track.
i will also get that headlight across to Brad on Thursday night!
I'm going to remove the booster on my 32 guys. I'm not going to put a pedal box in it, just some modifications to the factory arrangement will/should allow for a different pedal ratio. I'll get pics up when I do it and advise how it feels.
I'd be really keen to see this Ben as I'm removing my booster too
I've got a spare set of pedals out of the wreck which we can experiment on in the new car. If all goes pear shaped then we will still have the old set to use.
From memory, it's not the pedals that are the problem but the brackets which are weak. Wouldn't be too hard to machine up a set of brakets. Getting the body contorted under the steering wheel with the legs up in the air is the hard part!
The pedal itself is usually fine its the box itself and the mounts that are crap.
The originals are made from press bent steel and rubbish.
I make new boxes from 3-5mm thick plate thats all Tig welded together. They dont flex and work really well.
Whilst your making the new pedal box/mounts you can adjust the master cylinder height and pivot points to get the pedal ratio just right so it works properly without the booster.
Guys there is loads of info all over the net about calculating pedal ratios and so forth.
Oi you weren't there haha i dropped it off anyway. and called greg.
if you go in the morning greg will have it.
are you guys using a lift pump with a swirl pot, as that is a drag style cell. just wondering how you controll fuel surge. The bar work in your cage is amazing. excellent job.
yes
yes
yes
lol
this one:
16 gallons however much that is. bought it purely because it was a. cheap and b. had a level sender.
once the painting is done (really should do the subfames as well now the chasis looks good) we need to fabricate some mounts for the fuel system, rewire the car (we have decided to do it all except the engine loom, I hope you are still helping brad lol), mount the battery and attessa resoviour in rear passenger side, modify the rear subframe, get the new suspension arms in, reco the driveshafts, shim the diff, put some brakes on, put the windows in and door trims on, mount up the seats and harnesses, build the dash (standard one is heavier than you'd think), sort the headlights, water to air intercooler and piping, airbox, second radiator, oil cooler.
once we've done all that, all we need to do is get the motor finished (turbo and wastegate mount mostly) then go for a hoon.
russ...I've seen what you guys are taking on, you might take longer but it will be a hell of a result...
Yes using surge/swirl pot with standard GTR pump as lift pump and Bosch 044 (I think) as main. Still working out where it will go as the swirl pot is a tall as the fuel tank and we need to put it somewhere where it will drian back into the tank. Still trying to avoid the boot so we can avoid a rear firewall.
Maybe fit it where the atessa resevoir is and seal it back up. Depends on room.
excellent.....
brad are you sure they have information on the internet too now? I only ever seem to find porn
Shit we seem to have the same problem then. if you overcome this let me know how you went about it..
now on the topic of porn here's some i created earlier
As for selling the car. maybe not so much anymore but i wanted money for a business idea. might have to rob someone now the car is staying :(
hahah always borrow for business, at least it is tax deductible. personal stuff is where you should avoid debt....especially cars.
which reminds me of the raceworx motto....if you can't afford to write it off, you can't afford to race it. exactly why i stopped tracking the road car and bought a dedicated race car instead.
stuart like mark said, we are using a swirl pot....but that fuel cell is fuel filled and has a low pick up point so it should be acceptable even without. but I am dead sick of the 044 intank setup on my production car....can't go under 1/3 tank with it which means I am always carrying an exra 20kg in the rear (on top of the extra 20kg in the drivers seat lol)
yeh, should work. I opted for the alluminium tank and modified it. i welded a two litre aluminium sump on the bottom. hole sawed the bottom of the tank first to drop two 040 bosch pumps through. The tank cost $280. the rest was just material. ill see how it goes.
Edited by BezerkR32
looks neat stuart (and excellent welding too whoever did that).
we made some progress today, the engine bay is a subtle hue of red.
more importantly, the fuel cell is mounted up (mostly, just needs another strap around from the subframe, but that needs a tab welded on the right - nissan were kind enough to supply us with one on the left side, might have been for an exhaust originally?).
its hard to tell but the top sits flush with the boot floor. just need a cover/firewall for it now.
best of all, nissan provided us with an excellent spot to mount the surge tank and fuel pumps up here. attessa resoviour will move but we can live with that. looks like a very good solution
Hellooo everyone
just pulling the new motor apart and thought i'd ask in here as it will go noticed :laugh:
can i remove the stock oil cooler unit? and never put it back on? or is it needed? i do have a large greddy unit
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
