As requested........ let me know if you want it, i can possibly ask my mate if he'd fix it too if your interested.
there is no lip
and you can have the spiders too!
That'd be great Angus. If your mate can fix it even better. Happy to sling a few slabs around for the effort. Pretty sure I have a lower lip lying around.
nah mark! no arguments here mate... always like to throw up ideas, i am no expert so watch on with interest
you boys look like your making great headway!! keep it up , great job
i have to keep berry away from this thread or he will go off about me making him work on the r35 instead of his car! lol
Hey Russ, you had Mahle pistons in your 32 correct??
is there any secrets or tricks to using them/for the build??
Bad timing, i spoke to his misses and he is over seas for 2-3 weeks.
still want?
Yes please, I have someone else who can rubber/plastic weld.
When's a good time and where about's are you. I'm away until Friday.
What can I throw your way for the pleasure of taking it off your hands?
Thanks,
Angus,
Just had a thought. Going to machine up a couple of allow steering wheel linkages on the weekend, how does one of these sound. You can probably see one on one of Duncan's previous pictures, they replace the standard rubber steel one that links the steering wheel arm to the steering rack.
I'm going to whoreeeeeeee for a second or two....
I'm done whoring, now all i need is pistons and rods and i can build this damn thing!!!
Are these new turbo water and oil lines. If so, they are a really, really, really good idea. I have had to destroy a standard set on at least 3 occasions because the fittings wouldn't turn on the pipe and it ended up just twisting the pipe up until the metal fatigued and ripped itself apart. A real pain in the ass, not only because they needed to be replaced but because it's a bitch to get your hand and a spanner in there in the first place, then you have to turn hard enough to rip the pipes apart.
What's in the box under the VRS kit?
ahh sweet that would be great :O
Yeah all the turbo and water return lines there! from hose solutions on ebay all up around 350 aussie delivered ;)
that sounds similar to the way i pull things apart hahaha.
big black box is a nismo full engine gasket kit with a 1.2mm metal gasket too. i had some presents arrive this morning!
what do you think about the quality of the lines. we need a set too, and these are hard to beat at the price (about 1/2 what pirtek charge for the same) let us know if they fit ok.
ebay, they are from the uk they look nice.. haha dont think they will be getting fitted for a few months now
http://myworld.ebay.com.au/hose_solutions this guy is the one.
tho they did take some time to arrive i think around a month..
Ask Norm, Mr r32 how they fit.
Edited by Angus Smart
i can make you custom speedflow lines for around that price.
A question about Sump/Baffle
So i bought the tomei baffle, now i'm thinking why on earth i did this.
i wouldn't mind extending the sump but not making it go any lower like most other extensions, is this possible? and still use the tomei baffle?
interesting question. we are running the tomei style baffle in this car's motor too (although we got the much cheaper one from Just Jap), and the sump is wider but not deeper. remind me to post some pics next weekend
we normally run the trust (deep) sump, and I had spent years telling people yes they hang low but no you don't damage them. which was true until I smashed mine on a ripple strip at oran park earlier this year and cracked it in 3 places.
still, I've had it welded up and am going to put it back on - I like the deep design to keep oil near the pickup
Yes it is possible to still run the Tomei baffle with a sump extension.
Why would you want a 6 inch blond when there are so many nicer 6 foot ones?
Who does the braided clutch lines? and what is the benefit of fitting? Thanks
Edited by DiRTgarage
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
