yeah the pic I posted above shows the maltec braided clutch line, I got mine from UAS who have them in stock. couple of reasons for this car:
* it removes that ridiculous clutch damper system and replaces it with a direct line
* increased clearance to the fuel rail when motor is going in and out because the line comes out at 90o and goes straight down due to the banjo fitting
* removes the short factory line which I think is suspect after 18 years.
If you are running the sump extention, then you cannot run the sump baffle, and it would be pointless anyway. The sump extention comes with it's own round baffle, which is a cylinder with holes in it, which reaches down to the bottom of the extention. It welds on to the standard sump trays. It also comes with and extended pickup. The sump baffle kit would sit above the sump extention with the oil below it, making it pointless and it would foul on the baffle that comes with the sump extention kit.
You cannot run the TRUST one....but who mentioned TRUST?....not me...not Andrew...i thought he just meant extending the sump. I had an extended sump which i sold to a customer in the ACT which was extended below the Tomei baffle and had an extended pick-up...worked very well.
Edited by DiRTgarage
Well i was thinking of modifiying the sump around the tomei baffle style. so i could have a bit of an extension and use the trap doors tomei have given me, or maybe i can sell the baffle and go the hi octane one..
possibly do the rb sump similar to the wing style like the aftermarket sr20 ones
Yes it is possible to still run the Tomei baffle with a sump extension.
Why would you want a 6 inch blond when there are so many nicer 6 foot ones?
as for the 6' blond, your right a 6' foot size 6-8 anything would be ok also! haha
For simplicity id go the Hi Octane one...sell the Tomei baffle kit to someone with a streeter.The sump i had was already modified in Japan complete with baffle kit and had a box the same as the internal diameter of the tomei kit that extended down about 3 inches below the baffle from memory. It works well but the Performance Metalcraft/Hi Octane item is a better option and the one i went with. It will hold more oil too.
The clutch pedal in my white gtr was abit hit n miss with the factory clutch line, fitted a maltec braided line, removed that extension bit that runs beside the gearbox, fitted a new slave, went to wsid and the clutch felt soooo much more solid that on the second run my flywheel parted company :D
Yahoo, just got home and i have
And
Just waiting on Arp parts and i will be ready to build!
yahooooooo!
pistons were a bit of a mess, not sure if i like mahle's packing too well there a few tiny nicks hopefully they wont be of any problem.
hahah half your luck.....there are now 4 gtrs without motors in marks front yard. and 2 motors ready to go on stands, one ready to go on its subframe, and one ready to clean and assemble.
its like a fcuking wrecking yard.
btw brad I spoke to mark, drop by on the weekend, we can organise that bending....
And
yahooooooo!
Nice looking rods! Shame they'll be hidden in a block!
Wierd I was just mentioning that really nice n light intercooler on my olg gtr Duncan.... new owner has just posted it for sale, in case your interested;
http://www.skylinesaustralia.com/forums/Ar...er-t236454.html
And
yahooooooo!
I've been running my Pauter rods now for 5 years and 2 engine failures/rebuilds. Now partnered with a HKS stroker crank and shortened HKS coated pistons. They are almost indestructable.
haha thanks Ben I saw that thread....but the price is more than the rest of this car :) we're on this path for now, if we do ever give up I can't image anything except a chinese cooler going on :)
haha thanks Ben I saw that thread....but the price is more than the rest of this car :P we're on this path for now, if we do ever give up I can't image anything except a chinese cooler going on :D
I have/had a chinese cooler and cant fault it.
Finally got my dry sump belts today which was the only thing stopping mine from being finished.
Then onto the next one.
what are u guys doing with the g sensor thats usually under the console? can u move it or wont it work correctly anymore? im thinking of throwing mine under the dash area to get it out the way (obviously mount it level and straight as it is now), do u think this would cause any issues?
Don't think it's a good idea to move it. I'm sure it will still work, but it will work best when located in the most central part of the wheelbase. I suspect it should actually be moved backwards a bit.
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
