The dry ice works great. Don't know about burns, I decided to use gloves. -70 is a little cold even for me!
Couple of tips for those doing it, get extra dry ice. I got 7 kgs, and it was just enough, but it would have been easier and less messy to get 10kgs.
Keep a separate 2kg in a bag for doing odd shaped parts, vertical etc.
Also a hammer works wells, but a cold chisel works better. I found towards the end, that you can crack it with the cold chisel and lift it easy with a scraper without doing any damage to the paint, but for it really to work well, you need to cover the area properly with the dry ice. As I ran low, it got harder to do easily.
90% of the job was done in under an hour, but there's still a few hours cleaning the vertical parts and the silicone sealer.
I used gloves, but I leant on a piece with my elbow and started wondering what that stinging was... the burn hung around for weeks!
And good point on the extra ice. I started running low and it was a lot less effective. I could still hear it cracking, but it just didn't seem to come off in as large a chunks as it did with the fresh ice.
I personally don't know all the theory about it, but I had a long discussion with the engine builder and he was fairly adamant that squish zones of the rb26 heads are pretty good for a turbo setup. Much more and the piston's would have to be dished to allow valve clearance. The rb26 is a high compression engine, so cleaning the squish zones then decking it has it's set of problems.
Head porting is a magic art, one which I don't profess to know very well. It's not just a case of bigger is better. Velocity is very important for turbo spool up and so you don't want to port a RB26 head too much or you will gain top end HP at the expense of usable torque.
all true, and i've looked into 26 head porting a lot and talked to lots of different GTR tuning shops now in Japan and in oz too. and the ones whose opinions I trust the most and who have the RB26 experience to back it up tell me (in simple terms). street RB26 build = leave them alone, street/club track use build = remove one side, high power/high boost/track/drag use = remove both as it will enable you to run more boost, and more timing before detonation sets in. most of the serious race RB26 engines I can think of off the top of my head have done something with them, either removed one side, or removed both all together. we can agree on one thing though, there are lots of different opionions out there!
to expand further.
squish zones intact gives good off boost and boost building reponsiveness, but propensity for knock with any sort of decent ign advance and decent boost levels
one side removed is a one foot in each camp solution. lose a bit of the off boost dirvability, gain the ability to tune with more boost and more timng before knock
both sides, lose off boost and boost build torque but gain it back and then some with the ability to safely run big boost, and more timing.
Steve,
Glad we finally fooled someone with 31 pages of posting! We all got together and invented a secret code of automotive bullshit hoping to lure someone in.
Seriously though, take everything you read with a grain of salt. Everything is an amalgamation of opinions and not necessarily based on any fact. This forum is a good source of information, but all of us have differing views, which is what makes this so much fun!
to expand further.
Rich,
I understand the theory, but when you were talking to others about it, was there any discussion of decking the head to drop compression back down? From what I get from your post, removing one or more squish zone would essentially increase the volume of the chamber thus reducing the compression.
If this is the case, and lower compression is desired, couldn't a similar result be achieved by using a thicker head gasket.
My discussions with the engine builder involved more profiling the squish zones and then decking the head so reduce the compression back to a desired point. It was more about developing exhaust velocity and terminal speed on the piston.
Again, I need to point out that I'm no expert, more just trying to suck up info from different sources and trying to understand it better.
Steve,
Haha... I KNEW something was up! :)
Yeah I know, I learnt that a long time ago, there really isn't much solidarity to anything when it comes to cars... Like me for instance, I spent about 3 grand on stage one engine hardware (zorst, ECU, tune, intake) to gain 14kw... I thought it was very interesting :thumbsup:
My bank balance was very angry with me though :ninja:
I just like reading about what goes into something like this, it's something that I don't think I would ever see anywhere else :woot:
to expand further.
I was actually going to ask someone about head porting in the coming weeks, seems like now is the time.
My engine builder was originally a head machinist/head rebuilding guy so hes pretty switched on when it comes to heads and porting. he explained a bit about what he was going to do and showed me a rb26 head he was actually working on. which was a full head port job everything was really enlarged and cam areas were cleaned up alot to fit very large.
i was wondering how far to actually go, i guess a good cleanup on both sides is a good idea, remove the bump on the exhaust and maybe a bit of a knife edge, do i need to go any further??
i plan to run atleast 26+ pound or whatever the turbos will pump efficiently.
Mahle pistons, Pauter rods, 800cc injectors, and i guess a broken gearbox somewhere there too!!
time + space is easy, knowledge is the hardest bit of a build.
I love this thread :banana:
I'm really just posting so then it stands out more... I barely know what most of you are saying :banana:
hahah I've never let knowledge get in the way of enthusiasm :bunny:
andrew....our head has an interesting theory, who knows how well it will work but the headjob buys have done lots of different motors over the years.
anyway....the inlet is ported extensively, but the exhaust was only lightly ported/cleaned up, the basic idea being to keep exhaust velocity up for turbo response.
the head guy picked up a calculator before the air grinder. I thought that was a good sign
Anyone have any head bolt washers to spare? I was bolting up the head and nearly shit my pants when something went snap and all of a sudden the bolt had no tension. I thought it was a snapped head bolt, but it turned out to be a washer. Must of had a hairline crack. Anyway, they're very hard to find. I have a few smaller ones, but I can't drill them out, they are harder than my drill bits.
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
