your not re-using head bolts are you guys, thought you would have splashed out on a stud kit.
this could be an early warning sign. im all for cost conservation, but in the right places.
oh.
maybe we should lash out and buy a set:(
Pshaw, I checked the head bolts, they aren't stretched at all (I know you cant really check them like conrod bolts). Seriously, I have never heard of a RB26 headbolt being the cause of failure. I have heard of failure but not as the cause, more as a result of something else going wrong. Correct me if you've had it happen to you
umm well there was this one motor i had where the head bolts stretched enough that the head was rattling around and not holding any compression (or coolant)
you might remember that one :banana: can't really blame the bolts as you say they were effect not cause
hey dunc
you may already know this but if you go to heads studs over stock, if ya use ARP'S shorten them up as there too long and stick up about 10mm past the nut and hinder oil return flow & there already bad enough at that.
also make sure the studs dont turn as your tighten the head down especially if they are bottomed as it appears it can cause the cracking across to the water jacket.
cheers russ
from what i understand they are available to suit RB26, so you would think they were to suit standard block thread,
the newer series of studs have a allan head socket in the top. When i install them i wind them all the way in, then a half turn back out.
How do you stop them from turning? Does the block need to be tapped or is the thread the same as std?
I'm in Bankstown. i have two motors i pulled apart so i have a few sets spare headstuds. some from a r34 motor that wasnt used much at all and others from a thrashed out 32 sl$t
i bought new studs from arp and the bar is still at home too. hanging out with my good one
And Russ, you sure your not thinking about main studs?? i have the arp head studs at home and they are actually an Arp kit. where as the main stud kit isnt..
i have a turbo Question now
R34 N1 turbos aa403's with a 5mm larger front wheel. when i am rebuilt i wasnt to try somewhere close to 30 pound
i have a nice Arc cooler hks hard pipe kit and the hks hot pipe kit. i'm wondering if my Bastard turbos will flow that much air efficantly? or will i have to either turn the boost down or try maybe cooler spray or something else to keep inlet temps down?
Can't tell you absolutely for the 34 N1 turbos, but the 32 N1 turbos will flow 30 psi fine, but you will probably be flowing past what the internal gate can handle under heavy load, so even fully open they will probably creap. I would give them a try and change them only if you find them unsuitable. At this pressure, you should start looking at something with an external gate.
Did someone just say screamer pipe!! <3 my exhaust shop is going to love me. i'll have a chat to them about it.
if this is the case (external gate). then i may aswell sell my complete exhaust, get a custom dump/front system made and go ahead with the trust 90mm titanium exhaust.. shouldnt cost me any more than two wastegates and a few 100 bucks.
Let me know what you want to do about them bolts/washers? and the front bar. i will be in st peters till about 11pm tonite.
or live at Bankstown and work in Liverpool/Moorebank..?
the ARP'S i used were part of a kit for THE RB26, but maybe there has been an update.
the extra length of the stud compared to the original allen key bolt made quite an amount of difference to the oil the breathers would spit out on a lap at QR, ( like about a litre every 2 laps!!)
it was the only change we had made, we then cut em down & probelm gone again.
Can you give me a bit more info on this? i'd like to foward this onto my engine builder just incase its going to be a problem.
i know the main stuf kit needs to be cut down, wasn't aware of the head studs causing problems.
cheers :)
My GTR has been sitting stagnant for more than a month now... I'm sure the spiders are loving the rollcage as anchor points for their webs :/
If you guys don't want to work on your car, feel free to come and put mine back together! The pile of parts sitting outside of the car waiting to go back in, is taller than the car itself ;)
Studs are worth while, main studs as well.
Ive also had blocks with little cracks across water galleries, My machinist said it was more than likely from the studs bottoming out so now we also cut them down, loctite them in the day before assembly and liquid paper mark before tightening down.
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
