All it takes is a bit of practice, and I've had too much practice :laughing-smiley-014:
I think I did it about roll 2, so it should be fine. Was the last time I did it, and that one ended up on the roof as well.
Our first outting with the Dry sump was today. Oran park south circuit
Absolute success. Few minor dramas like the just jap silicon piping spliting and restricting it to 8psi, and rear brake issues but other wise it managed a 50.2 with stuff all power (sub 250Kw id assume)
Time to pull it all apart and switch shells now!
Edited by Risking
i was at OP on Sat arvo/night, went and watched Niel in the Radicall, looked like heaps of fun. Also met Duncan so good to be able to put faces to names. Was surprised at the mix of cars that were there. Street cars to race cars. NO SKYLINES. was a RB powered silvia that was quick. Did you go on Sunday?
yeah good to meet you too Stuart. now get your car finished and out there so there is at least 1 skyline around :P
we got the rear cradle back from John on the weekend, we now have a very adjustable rear end. still need to fit the hicas replacement arms to it then it is ready to go in with all the colourful chinese bits bolted on. Glad we bought most of the bits before the $AUD crashed.
but it was too bloody hot to do much on sunday.
Brad you better get a wriggle on, Neil dragged his radical around there in 48.18 on saturday
Duncan,
I think I'll clean up the original crush tubes and weld them to the top and bottom plates that I was going to make up to replace the cradle bushes. This will eliminate the need to add a bush to the bottom when bolting it in and make sure that the holes are exactly the right size.
Only problem is that I'm going to have to root around in the bin to find them. Sometimes I get the good ideas way too late.
I too was surprised at the mix of cars but yes it was a very hot day. Their was a nice clean red r32 gtr there in the arvo when I was out watching Neil but I did't get any laptimes from it.
well the good news is I never got around to putting them in the bin, they were sitting next to it cooling down after their roasting.....
You didn't, but I did. Thank god the kids aren't in nappies any more.
Oh I know that silvia all too well.
I have to see it pretty every day at work.
Ha ha your a funny guy mark,,,I'll bet you don't chew your fingernails anymore either.
Young Brad,,,Duncan's correct,,,but a wriggle on won't cut it. I consider my 48.18 as slow,,,i'm really chasing a 46.
Neil.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
