yeah it's easy to go nuts on the parts. i'm guilty of a lot of crap i probably don't need but is 'nice' to have. yep, I reckon anythnig under 400rwkw head studs aren't really a neccesity, cam cap studs, well as long as they are good or new, and are installed and torqued in the correct order then there is little chance of anything going wrong with them. the only times i've seen dramas with them is when they are being installed or removed improperly. i've also seen dramas with people installing head studs then having problems due to them not being installed correctly, with studs bottoming out etc. which is why I wouldn't go there unless there is going to be some really serious power and boost to come. :P over the years as prices on gear came down I guess people just were inclined to fit more serious stuff 'just in case'...
Tiger some wives have their own lappy's and surf in here while hubby cooks dinner.
haha actually some of us have wives who race in r35 GTRs while leaving their hubby at home/work paying the bills
still trying to work out if its a good deal or not?
What's the plan for this weekend? I'm not home til Friday night so can't do any pickups, but the weekend is free. Saturday is better.
not looking good mate....will try to turn a spanner or 2 on sunday
What are you guys using for cam cap bearing studs/bolts?
standard of course. don't forget our budget (ie 0). standard head bolts, standard main bolts, standard cam caps. and all second hand not new. if the motor blows due to failure in one of them someone can tell us "I told you so". otherwise we can just keep saving money where possible :)
wtf would you need cam cap studs? if you have a cam trying to push through the caps you have serious problems
I stayed out of this one, but I'm glad that someone else has piped in on the need for cam caps studs. Sounds to me like the biggest waste of money that you can put in your engine.
Let's just have a look at the mechanics of the whole thing, the force on the caps comes from the cams and the valve springs only. Under compression the valves are closed and the load is absorbed completely through the valve seals and thus the head bolts/studs.
Springs are inconsequential, even if you have heavier springs, they are not exerting much more force than factory.
So you've left with rotational force of the cams, which is only a product of the weight of the cams and the rpm. I don't know what the weight differece between aftermarket cams and standard is, but it can't be much and even if you are over reving it's unlikely that you will be doing more than 10k rpm (stupidity to be doing this much anyway) so at most a 25% increase.
Take all this into account and you are nowhere near factory tolerance. Add to the fact that studs or bolts and screwed into an aluminum head and it's easy to see that the cam cap bolts are not the weakest part of the chain anyway.
But hey, if you want to spend $230 on bolts, I'll discount them to $229.95 and just head down to Bunnings for some high tensile bolts. I'll even engrave them with whatever Jap brand name you want so that it has the bling factor hidden under the cam covers. :ermm:
I'll take two sets :wave:
i got them for $230 delivered
cams in this head are fairly sizable, 270/280deg 10.8lift
Good price, where from?
All the other bolts etc have been upgraded in this motor, so another couple of hundred wont hurt. Even if its not 100% needed, ill be straight above 400rwkw and i dont want it to let go again :ermm:
All the other bolts etc have been upgraded in this motor, so another couple of hundred wont hurt. Even if its not 100% needed, ill be straight above 400rwkw and i dont want it to let go again :D
I don't think it let go last time due to cam cap stud failure though.... :ermm:
still if you want it, buy it. but we did try to tell you! :wave:
dan from elite racing got them for me (erd.com.au)
Nope, better pistons and new ECU for this one :D
This one will have a fair bit more power though
Cheers
I am still having nightmares about those roads in the wet!! :ermm:
Re the rear cradle mods I can say it works, as we did to The Slot Car and I went to Wakey last Sat after completing both front and rear geometry changes, by raising pivot points, which raises roll centre, did a PB of 1 min 4.65 which was .8 sec faster than previous 1 min 5.4 when I had done rear pivot points and partial front, and best prior to that was 1 min 6.18 with a few other changes but the main one was raised roll centre. Car is a lot more predictable and flat in corners and does not slide or pitch like it used to, and much safer and easier to drive. Dunc and Mark you will love it.
See link for more.
Slot Car Mods.
How do you find the Tein RA vs the Bilsteins? Better? Worse?
Also, how much for a modified rear cradle for a GTSt/GTR, including fresh arms? I wouldnt mind re-co'ing the rear end in my car with all fresh arms, fresh wheel bearings etc. Also need to find a way to replace the rod end off the HICAS as mine are stuffed and Nissan want $400 odd for replacement ball joints. Its not so much the money, but surely there is a better, perhaps more durable way????
Roy, I've got a better option for removing hicas entirely. I should have it together tomorrow and Ill post some pictures.
Hey Roy, not cheap although if you grind your cradle bushes flush it raises everything about 25mm as mentioned as long as clearance to chassis is ok, which on R32 GTS-T is ? BTW I noticed no added vibration, although I expected to as locks the cradle to chassis with no bush. We also made a custom lighter Chrome Molly upper control arm in rear like R33/34 type have, as it does not need to go around the shock like Z32 and R32 have, which Nissan realised and lighter. The front upper are custom pivoting models which don't wear out or bend as they don't bind.
Re struts I have tried various spring rates, Tein RA, D2 ( waste of time) HKS, Tein Flex, Tein RE, Bilstein and now actually half and half as in Billy's in rear as abit softer than the Tein for Wakey. Hard to pic although I am now looking at what I think is the ultimate for the price range and that is Brillstein PSS9 adjustable shock version. They have huge range of adjustment
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
