Sounds Like Hard Work :rolleyes:
BTW Risking - Isnt it a CAMS requirement to have the Oil System Isolated from the cabin?
There is no such ruling that I was made aware of nor have been able to find. It only states that leakage into the cabin must not be possible.
2.5 All oil storage tanks situated outside the main structure of the car must be surrounded by 10mm thick crushable structure. In any case, no oil storage tank, not located within the main structure, may be situated aft of the gearbox or final drive casing.
2.4 Except if the cables, lines and electrical equipment such as battery, fuel pump etc, are in compliance with the requirements of the aircraft industry as regards their location, material and connections, they must be placed or fitted in such a way that any leakage cannot result in:
• accumulation of liquid;
• entry of liquid into the cockpit;
Should the cables, lines or electrical equipment pass through or be fitted in the cockpit, they must be fully enclosed in a cover of a liquid-tight and fireproof material. No oil, fuel or electrical lines shall be situated beyond 600mm on either side of the car’s centreline and must not run adjacent to the main fuel cells or within the crushable structure.
2.5 All oil storage
My tank is fully sealed inside the cabin ( ill put up a current photo latter) and my breather runs out the OSR inner guard via a filter. All my lines which run inside the car are in accordance to the 600mm rule. I did get knocked back on this the first time it was looked at.
According to the rules unless you have a fully sealed rear fire wall OR have all breathers exiting to the outside most dry sumps I see floating around are infact not in accordance to the rules.
Edited by Risking
Back to my on a budget..... or something like that engine build.
Talk about bearings
Main bearings i'll start with..
i pulled out the crank lastnite of my N1 motor. all the bearings look pretty good for someone who has no idea how they are ment to look. all were Nismo items and i noticed the numbers on the bearings changes alot.
when buying new bearings say acl for example, i can only see two part numbers. standard and oversize.
but nismo offer around 6-7 different grades
whats the score here? do i go with acl? and how do i know which to buy? i take it i will need to get out the verniers and measure the crank in each place?
should i leave this up to the engine builder?
:D
nothing wrong with the ACL gear we have been running it for years. and its the right price.
And, despite my history, I would definately leave it to the engine builder - give them the block and the crank and ask them what size bearings after they've checked it out. then once you get the bearings check it all out with flexigauge.
acl have 2 sizes in big end, and 3 in mains
http://www.aclperformance.com.au/NissanRB26DETT.htm
Plus their "extra" size which is 0.025mm over standard for a little more oil than normal on a standard crank.
Measuring bearing sizes is not that hard with the right set of feelers, but, and this is a big but, you could get away with it if you kept track of each bearing placement on removal or if they were all the same. If none were really damaged, and you could look them up from Nismo, then it would be very easy to match with and ACL version.
As long as you crank came with your block, then it's been tunnel bored and shouldn't need much more than a good clean with some wet sandpaper.
Of course, if you've got an engine builder doing all the assembly, it's all pretty pointless as any decent builder you're paying money to will check everything first and tell you which bearings to buy.
I wanna see pics of your car getting crushed goddamnit
shit we should have taken pics of it on the trailer,,,or did you take some Duncan???.
Crushing pics,,,are you in one of your nasty moods again,,,.
lol yes.
no i wish i did but i didn't :P would love to see the rest of it getting made into a coffee table but I missed that too. at least the damn thing won't draw our blood again (except maybe that glass left on the grass)
Yeeerp i kept note of where every thing came out of all numbered etc etc. tho some of the nismo numbers are no longer listed on their website or in any web stores..
i might give it another search around for the numbers and see what i can come up with. tho i guess i may aswell just let him buy them as they are not that expensive.
No pics, I couldn't take them through the tears. Actually it was all over so quick I didn't get a chance. The cage may have survived the roll down the hill, but the massive jaws of the crusher made mince meat of it in seconds!
what happened to this car??
yeah acl are good price, ebay usa and stores for around 100 usd. but 150 sounds better.
Got my ACL race series (no discount price) $260 from Rocket industries. Mains and big end bearings.
I'm sure you can get em cheaper, but thats what I paid.
Your item is being processed by customs in AUSTRALIA. Sweet pistons and rods will be here tomorrow or thursday, usps says the 3rd but this could mean america's dates.
i will get onto the bearing thing soon. there wasnt any known problems with acl bearings? old stocks? etc etc?
Massive roll-down a hill at targa tassie 2007,,,the cars finally gone to GTR heaven and Marky's wife can now breath a sigh of relief.
I'm sure pics will be forth coming,,,nothing like taking the piss,,,I have them but crappy SAU can't resize them.
Looks like you two are on your own this coming weekend,,,I have to put my rear end back in and get ready for oran park the sunday after.
Love as always
Neil.
Andrew dont go and buy any aftermarket bearings without grinding the crank to suit them.
Factory bearings are graded so you can get the correct clearance without the need to grind the crank. You just select different bearing grades to suit any irregularities in the crank or tunnel.
Aftermarket bearings like the acl's should have the crank ground to suit them not just thrown in.
I would normally grind the crank so its a tight clearance and I know it will need more, mic up the crank and tunnels, flexi guage the clearances to confirm my measurements, then work out what needs to come off each journal before re-grinding the crank to the exact clearance.
Its time consuming but rewarding when you know each clearance its right.
Alot of people will take the 10thou off the crank, flexi-guage it (not knowing how to do it properly or accuratly) then assemble it with whatever clearance the crank happened to be ground at.
Thats just the way my machinist has taught me to do performance engines and it works for me.
Another vital is to check the crank is straight. You'd be suprised how bent yours may well be even though the engine was a runner and in good condition.
Dont touch it with wet/dry or any sandpaper.
If your going to measure it up use a micrometer, vernier callipers are not accurate enough to calculate bearing clearances if you decide to do it this way. If you need a set of internal mics your welcome to borrow mine.
Edited by Risking
all the bearing sizes are stamped on the front of the crank. there is a chart you get from nissan and you use it with the numbers stamped on the crank to disipher bearing size. after market bearings are all the same size. crank grinding or linishing is a must when using them. micking the crank and then the tunnel is much more accurate than plastiguage also.
I've been looking at that guide in the nissan manual, which has led me to ask these questions as i figured from what i read there are many different combinations needed. as the numbers/letters vairy on the crank and on the block.
its going to be a job left up to my engine builder :D
and i ordered all my Arp parts.. but nothing has come off the cc, or there is no contact in america from the guys. they are in what i can figure out Minneapolis. i dont think thats anywhere down south where all the problems just were..
Edited by Angus Smart
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
