I've been looking at that guide in the nissan manual, which has led me to ask these questions as i figured from what i read there are many different combinations needed. as the numbers/letters vairy on the crank and on the block.
its going to be a job left up to my engine builder :P
and i ordered all my Arp parts.. but nothing has come off the cc, or there is no contact in america from the guys. they are in what i can figure out Minneapolis. i dont think thats anywhere down south where all the problems just were..
Mate I have a decent amount of nismo bearings in stock in several different grades if you know what grades you need and decide to go with nismo instread of aftermarket send me a pm with the grades you need and there is probably a good chance that i will have them.
We packed a lunch on Saturday and trecked down to Just Jap to raid their warehouse. As usual Steve had everything we could think of and at excellent prices. This is the booty....
so.....lets see how good you guys are. the person to identify the most parts wins glory within this thread.
We put all of the front end stuff on except the sway bar links. and now the 17in wheels dont fit any more.
we also mounted up the oil filter relocator, oil cooler and found an interesting spot for the power steering cooler.
Yeah, I noticed the remote canisters. Are they D2's?
I spy with my little eye...
Oil adaptor
Coilovers
Castor rods
Front and rear camber arms
Rear LCA's
Silicon radiator hoses
Radiator
Swaybar
D2 (355mm?) brakes
Thermostat
Some sort of energy polarizer, though could be a flux capacitor
A little more work and a few more pictures.
A bit of milling on the dogbones and 356 mm brakes fit under 17" wheels! There's about 2mm to spare on both sides, but they fit!
Some tabs added to the intercooler/flux capacitor and the surge tank. Also some plates made to cover the surge tank and fuel pumps in the rear quarter and plates for mounting the radiator and to cover the hole left by the brake booster.
Last but not least, our new NOS tank!
There's something to be said for a 2-pac baked on paint job. The red on this car is coming off just looking at it the wrong way.
Before we put too much back, should we look at baking the current paint job in a booth?
Mark
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
