Duncan mark decided that the Speed input was needed for diagnosis latter on down the track.
I dont have the diagram infront of me atm but from memory pin 7 is the tacho signal correct??
The check connector coming from that is not needed.
Pin 1 should be the output to the ignitor for cylinder 1 and on the output side if the ignitor should be the timing light loop.
You are correct all those pins should be grounded and you'll find that the all join up inside the loom and ground to one point at the front of the plenum. Two points actually.
The ECU and other control modules always drop relays to ground once you get your head around the negative triggers its all simple stuff.
Same as the Attessa, its not hard just need to follow the wiring diagram. Like I said to Mark if you cross out each wire on the paper as you move/shorten/remove it that way your always left with a loom thats only got what you need and your always sure everything will work.
Im starting on the white car hopefully over the long weekend. Think ill take even more out of it this time.
theres a blue car over here too when you get bored!! haha
Ill take it for another wrap tommorrow, or you can since it is technically your car now.
hmm not sure if jess will agree with that :thumbsup:
anyway....not much work on the nugget today (manifolds are modified, cut, welded and cleaned up) but Mark thought he needed another project on the go.
so....he took one of these:
added this:
and created this in about 3 hours.
uh-oh we opened a vortex to another dimension. i blame that particle collider thingy. or maybe the flux capacitor in the nugget
speaking of which...how low is it?
I guess the seller thought it would be cheaper if they removed the springs first
its amazing how much easier this is than the old tar and scraper caper. It took more like 3 days to strip the first car we did
did a little bit of work on my race car too....front end suspension is back together with all adjustable bits now (thanks Gary!) guess i better get a wheel alignment before I try and drive it again.
we are doing engine stuff tomorrow - putting the good rods in the nugget's motor and assembling my race car's motor (well up until sealing anyway)
Looks almost as low as mine. He'll hate any sort of angry gutter or speed hump with a passion
The worst part is when the front wheels come back down the other side of the speed hump its very very easy to ding the bendy part of the front pipes on the top of the speed hump
Dry ice is over rated. I left my race car at Benm's place for a few years and he did all the hard work for me!
Speaking of which We repaired the firewall and so forth today and added some much lighter pannels. So now its cage time Duncan!
Duncan Jess was actually floating around where the passengers seat used to be for the first drive.
Also had another wrap around the block in the Grey car when Charlie dropped past. Cant wait to get it back out this month.
cars are *never* finished.
we did some stuff on the nugget's motor today. we had a set of nice rods (toga? or something) but they were on the outside of the motor. so we took it apart and put them on the inside.
gee the head is pretty.
and it gets the nice forged pistons and rods.
while my race car gets the crappy standard ones
Did you just use a knife or the likes to get the gule off from them floor pan seals - pan to fire wall, pan to rear well etc
that body filler crap? heat gun, scraper and patience. and as you can see the dry ice was no good for vertical surfaces either. but still.....sooooo much easier.
jase....bigger but a little lighter too.
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
