me too! 100%.
from what I understand though removing the squish zone isn't just about reducing the compression, that's more a by product, and as you pointed out can be returned by skimming the head. I think it's also about the shape of the chamber. obviously with those 2 pads removed you get larger volume but also the shap is different. I think the idea is having a smoother bowl shape gives less hot spots. in a normal head you get hot spots where there are any little angles or casting imperfections and the can cause pre-igntion or uneven combustion. by removing the squish pads you raise this threshold. the aim of course is you can run more timing and more boost which i'm told outweighs any other loss you might have (on a race engine). what convinces me further is that of the fastest GTRs I know in oz and OS, the ones kind enough to share with me what they do headwise they tell me they remove them. I should point out again for a street car the trade of probably isn't worth it (unless you have silly power) as you want be running enough boost and power to make the most of it. but doing one side is aparently a good compromise. for a race car most of these guys tell me both sides is the go. :banana: my own head? I did one side. I'll dig up some pics for you in a bit.
To remove or not to remove, that is the question? Sorry Bill.........
In a race engine I never do, because I lose too much compression that I can't get back with head/block machining because of the piston to valve clearance. I am not fan of cutting flies in pistons as that just gives even more hot spots and a thinner piston crown under the flies. You have to keep in mind the reason for squish zones, which is to concentrate and accelerate the mixture towards the spark plug, thus avoiding the potential for incomplete burn at the outer extremities of the combustion chamber. This has the by product of reducing the tendency for uncontrolled burn, more commonly called detonation. Back in the bad old days (of huge lag) decompressing an engine was considered an OK thing to do. But as we got a lot smarter in our tuning, the fuel and intercoolers got better, the need for low compression ratios disappeared. Although some dinosaurs still cling to it.
In a race quality engine, whether it is used on the street or not, I can’t see any reason to do away with the squish zones any more. Unless you use crappy fuel with a lousy tune and don’t care about lag ie; the car is used for drag racing with an auto. I still see some huge boost engines doing away with the squish zones, but that has more to do with poor efficiency in the engine which is what makes the huge boost necessary. If people spent more time on improving the efficiency and increasing the airflow instead of simply turning up the boost, then they would find it unnecessary to decompress by removing the squish zones.
Cheers
Gary
...If people spent more time on improving the efficiency and increasing the airflow instead of simply turning up the boost, then they would find it unnecessary to decompress by removing the squish zones......
well cmon then...we need ideas that fit within the budget of this project (ie $0!).
BTW the sway bar links sit a little different to standard, should I run longer bolts with lock nuts to get them closer to vertical? I think they might bind up a bit on their current angles.
Doesnt that suck andrew!!
I heard on the grape vine your doing the O/P day/nighter,,,True,???. If so can you bring my spare windscreen honey.
We could actually share my garage and cut the costs. No 15 is mine and if no-one take the other half we end up with tons of room.
Neil.
speaking of bits being dropped off, 3rd time lucky - the remote filler and roll over cut out for the fuel cell arrived today so thats another job to knock off in our spare time.
BTW we were discussing on the weekeknd......does a sway bar or "anti roll bar" actually stop or reduce the number of times a car will roll? If so that purty yellow solid one that Gary made up for us will be a must.
I bet Mark wished he had a bigger anti-roll bar on this car....
In a race quality engine, whether it is used on the street or not, I can't see any reason to do away with the squish zones any more. Unless you use crappy fuel with a lousy tune and don't care about lag ie; the car is used for drag racing with an auto. I still see some huge boost engines doing away with the squish zones, but that has more to do with poor efficiency in the engine which is what makes the huge boost necessary. If people spent more time on improving the efficiency and increasing the airflow instead of simply turning up the boost, then they would find it unnecessary to decompress by removing the squish zones.
Cheers
Gary
Thanks for the explanation Gary. I know of one engine builder who agrees with you and he was responsible for the head porting on ours, and personally, I did not want to once again remove the head before even firing it up and disassemble the head before even trying it.
Mark
I dont really know?? haha what a headache it all was tho. i need a 32gtr with a getrag in to test.. or mine will be ready in a month or so..
Looks cool though! Got a sort of croc theme going. What sort of weight savings over chromoly welded tube?
this is just under 9kg's (can handle 2000ft/lb) tho the other available model is around 6kg's (1000ft/lb)
i am wondering why i went with the larger one in the first place.... oh well i aint waiting another 7 months for one.
Neil.
I was going to but all the spots were full by the time I got my entry done. (was waiting to get the car sorted before sending it)
Greg got his in as did Steve Berry so ill probably be there anyhow.
bar thickness divided by the number of adjustment holes equals the maximum amount of roll-overs posible with the bar fitted.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
