Duncan's too scared to tell everyone, but the cars going to have, at least in the beginning, chinese turbos. Yes you heard the lunacy here first, but instead of the 2530's I've ordered a pair of chinese turbos and an external 50mm wastegate. I'm pretty confident that the setup will provide a pretty good balance of low down torque and not peter out as happens with internal wastegate turbos.
A/R is .63, which may be a bit laggy, but I'm hoping that they will come on full at about 3800 and boost solidly right through to 7500. I'm a big fan of smaller turbos, but if this doesn't work, I'm going to have a tough time holding Duncan back from the 3L conversion.
I intend to get the turbos properly balanced before going ahead just to make sure, but if they come in alright, then they are going on!
Let the flameing begin!
Mark
we shall see how the yum cha turbos go. personally i'm hoping they will be a winner but the 2530s are going to be hard to beat for this application.
unique1, can't remember exact figure but it was under $5k. its unregisterable, I think it was rejected for sevs compliance so worth nothing except parts....or as a cheap race car :ermm:
lol nice turbo choice :geek: 5k for the car complete thats crazy cheap, any ideas where to find similiar bargains? ive searches my105.com etc and nothing :huh: im looking for a race only one as well, im still deciding between gtr and gtst though, its a tough decision.
yeah mate, cheap unregisterable cars come up pretty often, I posted a $9k R33 GTR up about 6 weeks ago. Just keep an eye out, its a buyers market so you can get some real bargains if you aren't in a rush :wacko:
Even cheaper still is to buy someone else's already prepared car - as far as GTRs go the place to look is old Targa cars. There are at least 20 targa gtrs in aus and only about 5-8 are still racing. The big cost in building a race car is not the shell, its the cage, suspension, wheels and tyres, motor, fabrication to suit, recoing driveshafts/tailshafts/diffs/gearboxes/xfer cases you get the idea
Yes I do need that light.
Even better bring us the whole bloody car and we can get it back out on the circuit this year sometime.
Id try the china turbos if your happy to do so, why not!!
2530's would be a good option.
I wouldnt rule out GTRS' either but it does make the thing a bit harder to drive on tighter circuits.
Edited by Risking
Mark, you know very well his addiction to breaking perfectly good motors :banana:
Yeah, I've witnessed, been involved in the event, caused at least 1, and helped him take the motor in and out more times than I can count. We've done it so often that a bunch of plebs like he and I can take the motor out in under 2 hours and put it back in in around 3. He's even got to the stage where he can do the contorted starter motor bolt dance and only need about 3 skin grafts for his hands. :banana:
hi
we did a flywheel and clutch change in the gtr at the IPRA nationals last year in 32mins (at the track on the ground)
engine change at last round 6hrs drive in drive out, thats changing everything onto another short motor as well.
dave
BSM Motorsports
Damn it, now you've set me a challenge Dave! Have to wait til Duncan breaks another motor to try again. Should be sometime next week :P
Do you guys drill out some holes in the back of the sump so that you can get to the 2 10mm bolts in the rear main seal girdle? I've often though of making a couple of holes in the 2 winglet areas so that I can get a 1/4 drive socket in and remove the bolts without having to remove the gbox. In theory, you should be able to drop the sump in car and change a spun bearing, blown diff, or in my case swap my sumps between standard and extended.
Haha dont worry it will be coming around for sure :P still waiting on the motor...
I think you would destroy the spray gun nozzle in a matter of seconds, most sandblasting kits are only $30.
Wouldn't destroy it, wouldn't do anything at all except maybe clog it permanently. Spray gun is far too small to allow anything as big as sand through it. As ben said, sandblasting kits are cheap. You need a decent compressor, but the kit is really just a container and a gun. The booths can be costly, but if you are not doing it much, then you can just wear a mask and forget about collecting the used sand.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
