Yup the weather has been annoying the past 2-3wks coz I need to spend a solid 2 days working on mine out in the open but everytime it looks like the rain has moved on we get another light shower grr.
lol need a garage at all first :D
Neil.....admit it was fun tipping that car onto its head. And suprisingly little blood was lost between us. Interior looks a little more dangerous though
you need garage in floor heating!
a 6.2kw in floor cable system costs about $800 and is tied to the reo mesh before slab is poured...runs on off peak and costs about $1 a day to run. We did it in the last house we built...but not the garage...will not be so silly to overlook the garage in future.
Duncan's too scared to tell everyone, but the cars going to have, at least in the beginning, chinese turbos. Yes you heard the lunacy here first, but instead of the 2530's I've ordered a pair of chinese turbos and an external 50mm wastegate. I'm pretty confident that the setup will provide a pretty good balance of low down torque and not peter out as happens with internal wastegate turbos.
A/R is .63, which may be a bit laggy, but I'm hoping that they will come on full at about 3800 and boost solidly right through to 7500. I'm a big fan of smaller turbos, but if this doesn't work, I'm going to have a tough time holding Duncan back from the 3L conversion.
I intend to get the turbos properly balanced before going ahead just to make sure, but if they come in alright, then they are going on!
Let the flameing begin!
Mark
Dont worry, DUncan wont let the bearings stay together long enough for the turbos to let go :P
lol need a garage at all first :P
Yea great fun indeed, Especially slamin it back on to the ground. Oh kickin the mirror off was also a highlight. Sorry Markey but it's all about pay back for all the blood spilt and dirty fingernails over the years.
I promise to love and cherish your next one.
Steve-oooo,,,you own a build in progress GTR (I wonder why),,,,so don't get to cocky as I will laugh loadest at your misfortunes. If you think for one moment all your dry sumping la-la-la is going to give you a relaible car you might want to put the ice pipe down about now.
Neil.
and thats the truth! always something when racing.
i split a gearbox in two last year at close to two hundred kay hour, then the grass i pulled up on caught fire! the whole lot was throw away nothing useable in the box at all.
Opened the turbos up last night after bringing them home. The quality is surprisingly good for a something so cheap.
Some issues though, specifically they have a different exhaust fitting to the normal t28 GTR turbos which will mean some modifications.
I was aware of the T03 exhaust inlet was larger, but this didn't worry me because It's a pretty simple matter of getting some new flanges and cutting the old ones off and welding the new ones on. Also will allow us to change the angle if needed to make the fit better.
Exhaust outlet is not so easy. I thought that all five bolt exhaust outlet were the same, but apparently not. They are larger than the t28 5 bolt, so the dump pipes we've got are not going to fit. If I'd known I would have just got 4 bolt exhaust type and flanges. Anyway, not the end of the world, there are options, adaptor plates, flanges, something will work.
Details on the turbos are:
.50 a/r compressor
.63 a/r turbine
.57 trim
Turbine wheel:
Exducer: 2.48" - 63mm
Mayor : 2.89" - 73.4mm
Compressor wheel :
Exducer: 2.07" - 52.6mm
Mayor : 2.36" - 59.9mm
As a comparisson, 2530s below:
TURBINE:
Wheel = 53.8mm
Trim = 76
A/R = 0.64
COMPRESSOR:
Trim = 63
Inducer = 47.7
Exducer = 60.1
A/R = 0.60
By the specs, they should spool up slightly faster, but will probably peak sooner. External gate may change this, but we'll see.
oh while we are doing difficult things, does anyone have ideas on a filter for the fuel system? need something big, cheap and easy to get to mount in the boot. fuel cell and brackets, surge tank and pump are easy enough. and where do we get cheaper fittings than those nasty expensive speedflow things.
No doubt the fabrication will be a pain in the ass, up top not so much, but definitively the exhaust side will be tricky as you don't get too many chances to get it right. All looks great when it's tested outside the engine bay, only to find it fouls on the firewall...
As to the fuel filter, I've already got a 1/2 inch traditional fuel filter, so that should do the job. Standard pinch fittings. We use the Hicas lines for fuel which gets 1/2 inch of flow up to the fuel rail. Overkill, but it costs nothing and the fuel filter can be mounted in the engine bay or the boot.
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
