FOR SALE
NISSAN SKYLINE R31 S3 TI $4500ono
Engine: Built Nov 07
Full rebuild with re-bore, acid bathed block, head, rocker cover and inlet manifolds
Reconditioned head
High comp ACL performance pistons
Hastings rings
New bearings
Overhauled oil pump with new spring and valve
Graphite head gasket
Crow cam
New engine mounts
New timing belt
New water pump
New timing belt tensioner
All new fan belts
Electrical system:
New plugs Nov 07
New lead Nov 07
Reconditioned distributor Nov 07
New crank angle sensor Nov 07
New ignition module Nov 07
New ignition coil Nov 07
Fuel system:
New bosch fuel pump April 08
New bosch fuel pressure regulator April 08
Turbo injectors Cleaned and serviced Nov 07
Always run 98 octane since build
Cooling system:
New thermostat Nov 07
New thermostat housing Nov 07
New top hose housing Nov 07
New radiator Nov 07
New Water pump Nov 07
Genuine Toyota coolant
All new radiator hoses, heater hoses and bypass hoses Nov 07
Driveline:
LSD Diff from an import skyline
4:11 diff ratio
Gearbox Built with all new bearings and seals Nov 07
New gearbox mount Nov 07
Excedy Heavy Duty Performance Sports Tuff Clutch Nov 07
Overhauled tail shaft cv joint Jul 07
New Front wheel bearings Dec 07
Welded steering rack supports for extra strength
suspension bushes in:
Nolothane Control arm lower inner 94137
Nolothane Strut bar to chasis 48095
Nolothane Sway Bar link 42151
Nolothane Sway bad mount 42045
New genuine front sway bar washers
Nolothane Trailing arm lower 46093
Nolothane Trailing arm upper 46094
Brakes:
Genuine Toyota brake fluid
Slotted Disc rotors front and rear Dec 07
New bendix pads front and rear Dec 07
Custom Pod filter setup with ram air intake
Alarm and immobilizer Nov 07
Keyless entry Nov 07
Central Locking Nov 07
Power windows
New battery Nov 07
Lowered with King Springs
Koni r shock
ROH 17in Mags
Pioneer mp3 player Jan 08
American boss 800w 6*9's Jan 08
40% Tint Dec 07
A/c
P/s
Every step of this build was done 100% properly and professionally, I supplied the engine reconditioners with 3 heads before I found one they were happy with to be rebuilt as I went through 5 inlet manifolds before I found one without excessive corrosion. Any questions on anything please done hesitate to ask, I would prefer a text message or phone call over a pm or repost as I am unsure how often I will be able to recheck, however I will try.
Email Ryan [email protected] phone 0408 929 797
modify_inline.gifhttp://forum.r31skylineclub.com/index.php?...ach=27614;imagepost-51906-1212408471_thumb.jpg
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
