Hey guys, just a few items that have been sitting in my shed or room for a while now. Make an offer or better yet just call me and make a deal on 0423734866.
Items are located in South Australia (Just of Anzacs, for those in SA =)) Inspection more then welcome.
Item:Genuine Nissan Badge
Age:15 years?? not sure.
Condition:6/10
Price:$15
To Fit:Any car you want to put it on.
Comments:Its just a badge and has been sitting around for ages. It has marks and scuffs.
Item:Turbosmart Bleed Valve
Age:2 years?.
Condition:9/10
Price:$40
To Fit:Any car with a turbo (I had it on my r32 rb20 running 11psi.
Comments:Other cheapo brands of bleed valves are known for spiking.
Item:FET Turbo Timer w/r32 harness
Age:2 years.
Condition:5/10
Price:$30
To Fit:I had it on my r32 and was working when removed.
Comments:Removed as i had to go through regency.
Item:Tie Rod Spacers
Age:Brand New!.
Condition:10/10
Price:$30
To Fit:R32GTST
Comments:Purchased this a while back and never got around to fitting it. Installing this will give you extra degree in full lock. Essential for drifting. Also comes with instructions on how to install, step by step.
Item:Turbosmart Blow Off Valve Plumback Version
Age:3 years.
Condition:8/10
Price:$200
To Fit:Any car. I had this on my R32.
Comments:I also had this removed as i had to go through regency. It is very loud when not plumbacked, but sounds awesome.
Item:Genuine Kazama Adjustable Castor Arms
Age:Brand New.
Condition:10/10
Price:$300
To Fit:Was planning to fit to my R32 GTST
Comments:These are genuine Kazama Adjustable Castor Arms. Purchased from Tokyo Autosalon whilst they were on sale. All bolts are still sealed in their original packaging.
Item:5xT10 Dash Light Leds
Age:Brand New.
Condition:10/10
Price:$20
Comments:I purchased these off of 666DAN on ebay who also sells the same ones on SAU.
Plenty more pics so just ask =)
Thankyou for looking. :P
Edited by Min_R32
https://www.sau.com.au/forums/topic/222003-nissan-r32gtst-skyline-parts/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
