Originally posted by hippy
just be careful with an auto ... if its wet ... and she presses too hard ... woops ... can be bad .. very bad ... i know  :)... especially if she presses hard enough to press the switch ... and in the wet .. very very very bad!!! ... if u've ever been in an auto skyline u will know what i mean ... just the sudden power when u press too hard!!! just my advice thats all ..
AAAAhhhh Gotta Love the Switch :D
Female..... had a Mad ZX on P-Plates quite often scared the shit outta myself but i survived :) Now have a Skyline its Auto im alive - the cars in one piece so am I :D
haha but i would be more worried it could be the start of a lifelong obsession ...... amazingly enough guys get very jealous when you lavish your car with attention :D
  • Replies 60
Originally posted by Nizmo
AAAAhhhh Gotta Love the Switch :O
Female..... had a Mad ZX on P-Plates quite often scared the shit outta myself  but i survived :) Now have a Skyline its Auto im alive - the cars in one piece so am I :)
haha but i would be more worried it could be the start of a lifelong obsession ...... amazingly enough guys get very jealous when you lavish your car with attention :)
My pedal has one of those and its a manual! It seems to help the car sideways even in the dry doing 100kmh?
I think I can organise a 'NEW SWITCH' to be fitted on your 'go' pedal, that will take you back to the days of sideways Niz :D
zzz my g'friend drives a Lancer and she loves driving my R33 GTS-T. She loves the power, the feel, basically everything. And it is an auto, so make it easier to drive.
The problem she finds is that it is a bit hard to park. Been such a big car and all. My problem is that the rear end sometime just don't obey, especially in the wet hehe.
I think you will find that head and leg room in a R33 is better than a R32.
Insurance wise I reckon you are looking at $2k or maybe less because of your age.
Cheers
Guest saiyaman
ok then slip.... did you read my post when I said it was an r33 that hit the pole?
did I say I lost control in the s13?
The only car ive ever lost control in is an r33gtst
I actually explained that the back can slip and does when driving an auto because of the way it changes gears........ you should read my posts before replying.
did you want to say something useful or are you just there to give others crap??
I thought they only came in Auto's and were only there to turn the aircon off when you plant it? Maybe yours had a auto-man conversion rev ?
I've got a R33 GTST Auto and my wife uses it as a daily driver she loves the bloody thing, she drives it harder then me, she's a bloody hoon.
She defiantly gets plenty of looks.
She can handle the car quite fine even when she has her right foot to the floor, know she want's more power.
You might see allot of R33 but you defiantly don't see allot of R33 driven by females, most people see a Skyline and stop and look but when they see a female driving it they stop, look and drop there jaw.
no mine has a nitrous kit, my switch activates the nitrous when armed, all 100rwhp of it :)
Originally posted by Liquid
just jam a door stop under the accelerator for whenever she gets in it :)
excess power problem solved :)
And if she is anything like my misses she would take the door stop from under the accelerator and jam it up my ass.;) :uh-huh: :shake:
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
