are your wheels done up tight?
sadly though this often happens with spacers. the best best is just buy the correct offset wheel and bin the spacers.
spiggots/hub rings will cure that problem, spacers are great for increasing track but bad for this problem and a few others.
you can screw them till the studs break it wont cure the problem, and no a wheel alignment wont help either.
if your im melb give me a buz/pm i can make them up for you ....
sometimes you have to get them made up.
yes some tyre places will have them, but make sure they are a tight fit, there should be no movement when the wheel is on, NO movement other wise you will have the same problem again.
bryyy- your one of the lucky ones :)
Edited by robbieraver
it should do. sorry I just assumed your bolt on spacers have that little 'lip' in the middle to locate the wheel. if not then that is almost certainly why you are having these problems as it's pretty hard to locate the wheel dead centre without the hub ring on the spacer.
if it doesn't look like this, it's not good.
but they do make the wheels stick out a LOT so if your already filling out your guards.........
if your wheel is a standard ID then you can buy off the shelf spiggots for like 20 schmux
i needed custom cause ssr professor sp1's have a weirdo 79mm ID :D
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
