This box is located in the guard cavity on the passenger's side of the boot.
It has two plugs each with two wires.
I thought it might be the amplifier for the diversity antenna but the wires to the top plug are heavy by factory standards which suggests to me the box might draw more current than an antenna amp would need.
https://www.sau.com.au/forums/topic/222056-what-does-this-box-do/
ok, went out and had a look in my 32 shell and i have the same thing, never noticed it before. so i got looking around in nissan fast. according to fast there is a loom that goes to an antenna in the rear passenger side of all 32's (i have never seen a 32 with an antenna in that spot though).
fast also shows an electrical box in the rear passenger side that it calls a Coil/Noise Suppressor linked into the stock audio equipment. i think this is what it is.
That's interesting.
If that is the case I can bin it because the factory stereo is long gone.
I just want to be sure though.
One of the 4 wires to this box appears to be shielded like a signal wire.
There is an antenna in the back windscreen.
I think the connector for it is on the passenger's side.
I know the antenna uses an amplifier but I don't know where it is in the car but it would make sense if it was near the antenna.
I wouldnt be so sure. My mate had a 33 of which we unplugged something similar in that same area and his car started to jutter etc. Something to do with
fuel pump? ballast im not sure. But i wouldnt go unplugging it just in case =)
It's definitely not part of the fuel system because I'm currently rewiring my fuel pump and I've traced out every wire and component from a schematic diagram.
The fuel pump control module is in the same spot on the driver's side and the ballast resistor is in the engine bay.
Does anyone know where the antenna amplifier is?
Could it be a voltage regulator for the demister?
Yep it could be a voltage amp regualtor whatever lol.
But trust me on this i've taken apart 3 R32's before. It's got a wire that runs to the rear demistor. It's not anything to do with the fuel pump as they are on the drivers side of the boot. If you remove it, you'll be fine. I did on my old R32 and never once had a problem.
On a R33 however it is an antenna OR just below the antenna motor is the factory butterfly control fot the exhaust. But this is only ON A R33
Edited by Chang
If one of the wires goes to a terminal on the rear windscreen it might be the antenna amp because the rear antenna is in the rear window glass with the demister filaments.
Hmm true never thought of that, I ripped the stereo out as well as for the race car so didn't really matter.
Isn't the antenna only on the front windscreen??
Then whats the middle line that runs along the very centre of your front windscreen??? Its got a wire connected to it and only on some R32's not all. I always thought it was an integrated one?
Edited by Chang
Yeah the front windscreen has an antenna also.
The system is called dual diversity or something similar.
Possibly one antenna for am the other for fm?
I found the antenna amp. on a schematic wiring diagram but it didn't say where it is located.
