This box is located in the guard cavity on the passenger's side of the boot.
It has two plugs each with two wires.
I thought it might be the amplifier for the diversity antenna but the wires to the top plug are heavy by factory standards which suggests to me the box might draw more current than an antenna amp would need.
https://www.sau.com.au/forums/topic/222056-what-does-this-box-do/
ok, went out and had a look in my 32 shell and i have the same thing, never noticed it before. so i got looking around in nissan fast. according to fast there is a loom that goes to an antenna in the rear passenger side of all 32's (i have never seen a 32 with an antenna in that spot though).
fast also shows an electrical box in the rear passenger side that it calls a Coil/Noise Suppressor linked into the stock audio equipment. i think this is what it is.
That's interesting.
If that is the case I can bin it because the factory stereo is long gone.
I just want to be sure though.
One of the 4 wires to this box appears to be shielded like a signal wire.
There is an antenna in the back windscreen.
I think the connector for it is on the passenger's side.
I know the antenna uses an amplifier but I don't know where it is in the car but it would make sense if it was near the antenna.
I wouldnt be so sure. My mate had a 33 of which we unplugged something similar in that same area and his car started to jutter etc. Something to do with
fuel pump? ballast im not sure. But i wouldnt go unplugging it just in case =)
It's definitely not part of the fuel system because I'm currently rewiring my fuel pump and I've traced out every wire and component from a schematic diagram.
The fuel pump control module is in the same spot on the driver's side and the ballast resistor is in the engine bay.
Does anyone know where the antenna amplifier is?
Could it be a voltage regulator for the demister?
Yep it could be a voltage amp regualtor whatever lol.
But trust me on this i've taken apart 3 R32's before. It's got a wire that runs to the rear demistor. It's not anything to do with the fuel pump as they are on the drivers side of the boot. If you remove it, you'll be fine. I did on my old R32 and never once had a problem.
On a R33 however it is an antenna OR just below the antenna motor is the factory butterfly control fot the exhaust. But this is only ON A R33
Edited by Chang
If one of the wires goes to a terminal on the rear windscreen it might be the antenna amp because the rear antenna is in the rear window glass with the demister filaments.
Hmm true never thought of that, I ripped the stereo out as well as for the race car so didn't really matter.
Isn't the antenna only on the front windscreen??
Then whats the middle line that runs along the very centre of your front windscreen??? Its got a wire connected to it and only on some R32's not all. I always thought it was an integrated one?
Edited by Chang
Yeah the front windscreen has an antenna also.
The system is called dual diversity or something similar.
Possibly one antenna for am the other for fm?
I found the antenna amp. on a schematic wiring diagram but it didn't say where it is located.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
