Gday crew wonderin if by running my gtr in rwd not 4wd will do any damage to any components of the car in particular transfer cases atessa system etc?
I have air in the atessa system at the moment and am changing the clutch soon so wont bleed it till that is over, just want to check that im not doing any harm at the same time.
Cheers
https://www.sau.com.au/forums/topic/222083-r32-gtr-in-rwd/
Yerrrp a good thing to remember ABS will also be disabled!! not the best in this wet weather!
Your popping the wrong fuse..
Are you popping the one in the car, on the right of the steering wheel?
If you take out the one in the little kicker pannel on the right of the steering wheel, it will disable both ATTESSA and ABS
Try taking out the one from the engine bay.. I havent had any problems with ABS being disabled with that one..
In terms of conflicting stories is that you can't do the same with R33's and R34's GTR's. Thats where it gets blurry.
With R32's its fine. I have run my GTS4 for long periods of time in RWD and have heard many stories of GTR's being run in RWD aswell for long periods of time without any problem.
If you take out the fuse, you make the ATTESSA circut incomplete. If it is incomplete, it will not sence the diffrence in G forces (which is what activates the front wheel torque) and will not engauge the transfer case and hence, front drive shaft, diff and wheels.
https://www.sau.com.au/forums/topic/222083-r32-gtr-in-rwd/#findComment-3914387
GTS4WD is spot on. there is no need to disable ABS to disable the AWD. the reason people do is that they are lazy and just remove the fuse from the in cabin fuse panel. if you remove the AWD fuse from the engine bay all it disables is AWD. ABS is left intact. and no it won't harm your R32 GTR to do it.
https://www.sau.com.au/forums/topic/222083-r32-gtr-in-rwd/#findComment-3914665
Just thought i might add a mention to this..
Rmoving the fuse in the cabin removes power to the attessa/abs ecu, removing the fuse in the engine bay removes power to the attessa pump motor. This also means that you can't just come to a stop and jam the engine bay fuse in, like you can with the cabin fuse, and expect awd to come back.. Engine bay fuse requires a shutdown of the electrical system and firing it up again as you have driven the awd/abs ecu into a fault condition, it needs a reset to go again. (more pertinent to those that have switches rigged up).
https://www.sau.com.au/forums/topic/222083-r32-gtr-in-rwd/#findComment-3918658
Ahh, nope.
Even with a switch rigged into the fuse line in to the attessa ecu (in cab fuse one) you still have to be at a standstill for it to reset, otherwise it will fault.
Another way of faulting the atessa ecu is to turn the electrics off and then back on whilst still moving.
Edited by heller44
https://www.sau.com.au/forums/topic/222083-r32-gtr-in-rwd/#findComment-3920981
  • 4 weeks later...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
