HI All
im about to spray my series 1 rear garnish the same colour as my car.. so my question is
what do you all recomend to do to prep the garnish before spraying the primer, do i just use some kero to clean off all the oil and grease or do i
need to sand it back with some wet n dry paper to roughen up the surface a little bit???
Cheers,
Corey
https://www.sau.com.au/forums/topic/222098-plastic-prep/
HI All
Cheers,
Corey
Dont use kero. It will leave an oil residue and the paint wont adhere properly.
I give mine a fine sand with wet and dry, Clean it off with prepsol, then use a plastic primer (available from super cheap in pressure pak cans) then paint it and finally clear coat it.
This system works well and even under the bonnet using non heat proof paints it has stuck well and looks good.
https://www.sau.com.au/forums/topic/222098-plastic-prep/#findComment-3914461
I only use it on black, plastic primer IMO doesnt seem to make it stick any better IMO its what causes the paint to bubble under heat when its closed in a car.. The spray paint can is prob not as good as the 2pak gear pros use.
It gives you a better base coat so black looks better, it also allows you to sand it back so everything is damn smooth so it becomes glassy and shiny but 3 months mine bubbled, twice. last one has not bubbled.
https://www.sau.com.au/forums/topic/222098-plastic-prep/#findComment-3916270
Out of a can? Or spray job? Yes if its a spray job.
Could be a range of things for eg a Knock can cause it.. But if it hasnt been knocked..
Heat - ussually yellows with this tho.
Oil/residue not cleaned off correctly.
Thinner or cleaner splashed onto paint either before or after.
But mainly its due to not corretly premixing the paint, heating the paint in hot water two minutes before will help the mix especially in colder weather (this is of course in spray cans)
https://www.sau.com.au/forums/topic/222098-plastic-prep/#findComment-3917905
yes it was premixing acrylic paint with thinner (1 paint:2 thinner - for clear coat), then spraying with gravity fed gun. The thing is it only happens in some areas and appears to be the top layer(clear coat). I mix it by pouring paint and thinner in a bottle, then shaking it to mix for a good minute
https://www.sau.com.au/forums/topic/222098-plastic-prep/#findComment-3917925
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
