Thought someone from this section may know the answer ??
My FJ20ET S12 Project is near completion and I have a couple of questions relating to sourcing bits.
1) cam cover plugs for ignition leads ?? - The rubber boot things - Does anyone know where to get these ? What the P/N is or what an equivalent would be ? Failing that - a P/N for the full set of leads with the plug/cover things ?? Also where to get these ?? Which shops would have them ?
2) The Half moon rubbers (end of cams) on the cam cover - I'v been told that you can get alloy half moons instead of the rubber ones ?? Where Where Where ??
Cheers for that !
https://www.sau.com.au/forums/topic/222117-fj20et-parts-questions/
I don't have any idea of the FJ20 parts but I would suggest you look at FJ20.com for the bits you seek.
The boots around the leads I would suggest are part of the leads and not a spare part as such.
The half moon parts you seek, might be very similar to that of the KA24E from U12 Pintara, so it might be worth taking a sample along to your nearest Nissan dealer to make some comparisons.
Nissan have a habit of recycling parts from other models.
Cheers, D
what state you in?
talk to Randy from NISSCO in Vic (bayswater).
he and his crew know FJ20et very well
http://www.nissco.com.au/contact.php
Address:
Nissco 1600 Workshop
2 Halbert Road
Bayswater North, Victoria 3153
Melways Reference - 51 : B10
Phone:
(03) 9761 4743
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
