As far as I'm concerned a bit of light load running just to get a working surface on the crankshaft bearings and cam lobes is all the babying any engine needs .
The loading up process (IMO) is about getting combustion gas pressure behind the compression rings which pushes them out harder against the newly honed cylinder walls .
Its a pity most Skylines don't have a tow-bar because if you could hang another thousand kilos off it the run in/load up process would be easier !
There is a bloody steep hill that rises up the Illawarra escarpment from north of the gong (Wollongong) which would make a great run in road - Bulli Pass is it ?
Cheers A .
  • Replies 44
Cheers A .
lol mines in a stagea (1700kg) its one heavy sucker anyway so loading it up is no problem :P
I would like to know why its stated its important to keep the motor off boost early on in the run in for, anyone got any ideas?
you mean the macquarie pass west of albion park on the illawarra highway? its fairly steep and has lots of accelerating and braking.
Edited by TiTAN
  • 3 years later...
thread revival
my new engine should be cranked to life in the next few days, my engine builder also suggests running the cheap castrol GTX 15w-40 variety of oil,
supercheap has a sale now so you can pick em up cheap !
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
