hey.. my machanic just put a block off plate on my bov as i am doing a turbo upgrade ... is this safe and will it now be quite when i take my foot off the throttle or will the air still make a sound as it redirects??? thanks
https://www.sau.com.au/forums/topic/222152-block-off-plate-on-bov/
  • Replies 48
yes its safe. You will still get some sound like a flutter
Dumbest thing ive ever heard.. Get a plumb back if youve got a bigger turbo recirculation helps with smoother transition of gears.. blocking off the bov will make the turbo chuff/flutter and make the car feel like its almost going to stop during gear change.
not sure what air your on about.
only if they like fully sik vl turbos uleh
WTF you clown, stop spamming this poor guys thread with your useless bandwidth wasting posts!
He just had a legitimate question, so came to this forum for support and guidance, yet he gets you.
What a joke.
yer i was afraid of that hahah.. how loud is the flutter sound ?? some one told my you need a bov or your turbo will spin backwards making flutter sound hahah i think not
had a plum back on there my tuner recons they will leak at around 16-18 psi i rcon it was leaking at 12
What a joke.
dont single me out, get a sense of humor.
Your tuner must be smoking the good shit
well i had an atmospheric on and the more i vented it the ranker it ran so i whent back to a plum back .. guess ill just see how i go with it blocked off if it runs shitt ill change it again,,,
i have mine blocked off, my tuner said it makes no difference in performance, or life of your turbo.
i have it blocked off purely for the sound.
all comes down to personal choice really.
what sound does yours make and how loud ..also this would be legal so no sticker :D
If your running an AFM, with a blocked off bov, it WILL idle worse and stall under heavy braking (due to extra vacuum).. not fun.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
