Hey buddy, adjust your attitude on this forum from here on in, or you will be banned.
u got ppl in this thread posting nothing but bs, im actually giving proper advice, sure i put a f*k here and there but cant u see why? man u wonder why SAU has repeating threads, cuz mods like u ban the wrong ppl.
f*k this is high school all over again hahaha :D
  • Replies 48
Yes, correct - one of the circular ring clamp bits hadnt been put on "straight" and that is where it blew off from. However, I'm still curious, would that constant pressure from not having a bov eventually damage the turbo?
He's referring to your abuse and language towards other members not your information... lol
maybe it wasnt obvious enough but my "abuse and language" is caused by other members posting bs.
meh watever.... :P
i originally had my bov blocked, found out the bov was stuck shut, i got another bov atmo) and found that my car run better with it blocked off. maybe my car was tuned with it blocked, that i am unsure of. my next step would probably be a plumb back bov.
also the sound of your bov blocked will depend on what mods you have, i have read on the forum that a pod filter and frontmount or big cooler will make the flutter noise louder. i have both a front mount and a HKS pod filter (suppose to make flutter loudest out of the filters) and the flutter noise is quite loud.
also i might add that the flutter noise is caused by air coming back through the turbo (getting chopped up) and comming back through the pod/filter.
many people will say that it will not harm your turbo as they run their cars like it for long periods, others will say it will damage turbo but i guess its just one of those things.
also you could probably get yourself a adjustable bov that has plumback option and atmo. so if you dont like the way it runs with atmo, you can plumb it, or you can tighteen the neck right up (turbosmart bov) which will tighteen the spring inside it and make it the same as it being blocked off anyway.
cheers
If your running an AFM, with a blocked off bov, it WILL idle worse and stall under heavy braking (due to extra vacuum).. not fun.
Actually, I didnt have a BOV fitted to my new forward facing plenum / intercooler piping - I put my foot down around the corner from the garage and my I/C piping blew off!
So im thinking if my piping hadn't blown of under pressure, surely it would hurt the turbo in the long run?
FWIW.. my turbo cefiro did not come with any bov out of the factory. I have no idea why but thats what all cefiro rb20's are like.. My car does idle fine, My car does not stall because of this hektik extra vacuum under braking. I'm fair over reading this crap from people claiming they know everything, yet they really have no idea what they're on about. Just listen to R34NRG and be done with it
I made up a block off plate on my R33. Only stalling problems i could report was if you gave it a decent hit of Boost then put foot on clutch and didnt release clutch. So basically. it would only stall if i wanted it to. However I removed the plate because it was making the car run rough and it would pop and bang a lot more.
Very Easy thing to make. Give it a go. If your not happy it takes all of a couple of minutes to take out.
Luke
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
