Hi, I was hoping someone could help with trying to maintain boost in between gear changes. It hits 16psi then drops right down to around 3psi. It takes a second or two and then gets back up there. Just not sure if this is normal for my setup which is as follows.
R33 GTS-t RB25DET
GT3540R .86
Turbosmart 48mm ext wastegate
Tomei poncams
Blitz SBC id3 boost controller
Apexi N1 exhaust/ hi flow cat
Fmic
all required supporting mods... makes 434 RWHP
Any suggestions would be greatly appreciated
https://www.sau.com.au/forums/topic/222175-boost-drop/
Either of the two will help obvious double clutching will keep the revs up during changes but the atmo bov kills boost as vents air instead of recirculating.
there wont be a difference in how boost is held between an atmo and recirculating bov, they both do the exact same thing bar the obvious part where on recirculates back into the intake
its normal for a turbo that size to take a second to respool inbetween gear changes. If you dont have a bov at all, that can cause the turbo to "lag" inbetween gears due to compressor surge, so get a nice sized bov thats going to breathe well and that should help.
Other than that, theres no real streetable solution, unless you like flat changing, antilag etc etc, its just the joys of having a large turbo on a smallish displacement engine
https://www.sau.com.au/forums/topic/222175-boost-drop/#findComment-3915317
Well you'd think that but how many people do you notice running insanely low psi gate opening or insane high gate psis? heaps..
So if it opens to early leaks, opens/doesnt open well/dose etc means boost is going to drop off because air is not correctly exiting the system.
Dont forget youve got that gate on there.. spring??
sorry i couldnt make out any of that lol
https://www.sau.com.au/forums/topic/222175-boost-drop/#findComment-3915353
Thanks for the reply.....yeah should have said. It has an atmo BOV with a soft and hard setting. I think it may be on too soft. I will adjust it and see what happens. It was on the car when i bought it...is the adjustment option just a rice thing?
https://www.sau.com.au/forums/topic/222175-boost-drop/#findComment-3915422
adjustment option will be for your bov spring to suit your vac/boost. if it's too tight it will comp surge, which is why they can be adjusted.
https://www.sau.com.au/forums/topic/222175-boost-drop/#findComment-3915434
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
