So I'm driving to my girlfriend's house tonight. I'm accelerating up a rather steep hill in third, when at about 3000rpm my car suddenly loses all power. It's like it hit a rev limiter at 3000rpm. The exhaust starts making a loud, rapid popping noise and the car shudders slightly.
It scared the shit out of me. The car drives fine otherwise, but you push it even slightly and the same problem occures.
Any idea what's going on? Thanks.
https://www.sau.com.au/forums/topic/222178-severe-power-loss/
Sounds like an ignition problem. Check your plugs/leads/ignition coils.
There is also a possibility you could be using low octane/tainted fuel (mate of mine had a similar problem with his Maxima as you described, he drove it was nearly empty and re-fueled - problem went away).
could be your viscus hub cluctch is f**ked happend to me kinda same thing ...if you havent converted to a electro fan allready check when you cars off and cooled down if the big fan blade at the front of your car spins with ease if its stiff thats your prob if not dunno bro hhaahh. good luck
hmmm.. wot about your afm? if the plug has come out doesnt it barely get over 3 grand? and its "like theres a rev limiter at 3000rpm"
just a thought...
cuz if the car has gone blind in the amount of air its sucking in, I believe it would cough and splutter or possibly even shudder as you said... and the poping may be the fuel ratio getting too rich/lean... cuz the car has gone off the standard air/fuel maps and has gone crazy:P
Exact same thing happened to me,
RB25DE issue.
Spark plugs and Coils are your best bet, the car will shudder non stop as soon as you hit over 2500 or 3000 rpm.
It happened to me last week and freaked me out, got new platinum sparks and splitfire coils.
Works a treat !!
MRXTCZ
Plats were provided by DRC in Greenacre man, his a good bloke, Gil's his name director of DRC.
I called him up basically after telling him ive been reading and told him what the symptoms were, and his like yup. Sparks are gone, and known hassle is coils, one of fix !
I was like hektik!! i bought the coils, and he supplied the plats and full service.
Anyways, Kez, trust me bruh, when u goto ur mechanic and just get ur sparks done, then find out it doesnt fix it, then you gotta go hunt down splitfire coils, then go back to him and get charged again to get them into the RB25, its a mad headache ripping the top end off to just get into the god damn sparks and coils -.-
I was smart though, when i took it to DRC, i told Gil i need the car in 2 hours, he got 2 mechanics to work on it, and was done in less den an hour and a half. ;) sweeettt!!
Trust me, you wanna go the full 9 yards once your in there, so might aswell mod it now, and tick that one out of your lil Holy Mod Book!
But yeah, i saw a coil replacement guide on here, just a few threads below this one, you COULD do it yourself and save the labour costs, but in my opinion i would just get it down to a garage, not a normal petrol station garage, take it to one that knows their S**T bout' imports.
MRXTCZ
P.S Hahahahaha Cris!! THE MAN OF THE HOUR !! :)
Edited by MR_XTC
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
