my gtr drives very well and i have just done a major service on it,
now after doing the coolant, i have noticed that sometimes when im sitting at lights or sumthing i give it a rev and the clutch fan spins loudly like it need to cool the radiator down more...
other times ill give it a rev and just a sweet rb26 rev, no fan wooooshhhh if you know what i mean,
its about 50% on and off. im pretty sure i bled the system, properly... cranked the heater and had the water level over the top of the head in a special funnel to bleed all the air, but the nipple on the top/side of the head, when i let that out, it was sucking, not spitting water out??????
it was like it was a vauucm line undun, sucking away.... whats the go
any1??
Not sure what you are talking about
Have you tried reving the motor while your looking at the cooling fan ?
maybe the hub for the cooling fan is rooted?
check the hoses for cracks or leaks
I experience the same problem too. If i sit at a traffic light for too long and then accelerate off, all i can hear is the clutch fan over the 26. It also does it after i start it up. Takes a good few minutes of driving before the noise goes away. I Would also like to know what's causing this?
Edited by quiksta
